OSPF is an interior gateway protocol (IGMP) used within large autonomous systems to distribute routing information. OSPF routes IP packets within a single routing domain (autonomous system), like an enterprise LAN. OSPF gathers link state information from neighbor routers and constructs a network topology. The topology determines the routing table presented to the Internet Layer, which makes routing decisions based solely on the destination IP address found in IP packets.
OSPF detects changes in the topology, like a link failure, and plots a new loop-free routing structure. It computes the shortest path for each route using a shortest path first algorithm. Link state data is maintained on each router and is periodically updated on all OSPF member routers. This enables routers to synchronize routing tables.
OSPF uses a route table managed by the link cost (external metrics) defined for each routing interface. The cost could be the distance of a router (round-trip time), link throughput or link availability.
Use the (config) instance to configure router commands. To navigate to the (config-router-mode) instance, use the following command:
<DEVICE>(config-profile-<PROFILE-NAME>)#router ospf
nx9500-6C8809(config-profile-default-ap8533)#router ospf nx9500-6C8809(config-profile default-ap8533-router-ospf)#
nx9500-6C8809(config-profile default-ap8533-router-ospf)#? Router OSPF Mode commands: area OSPF area auto-cost OSPF auto-cost default-information Distribution of default information ip Internet Protocol (IP) network OSPF network no Negate a command or set its defaults ospf OSPF passive Make OSPF Interface as passive redistribute Route types redistributed by OSPF route-limit Limit for number of routes handled OSPF process router-id Router ID clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile default-ap8533-router-ospf)#
Section contents:
