answer-broadcast-probes
Allows the WLAN to respond to probe requests that do not specify an SSID. These probes are for broadcast ESS. This feature is enabled by default.
Syntax
Parameters
None
nx9500-6C8809(config-wlan-1)#answer-broadcast-probes
Related Commands
no (wlan-config-mode)Does not allow this WLAN to respond to probe requests that do not specify a SSID
