Use the (profile-context) instance to manually configure a L2TPv3 manual session. To navigate to the L2TPv3 manual session configuration mode, use the following command in the profile context:
<DEVICE>(config-profile-default-nx5500)#l2tpv3 manual-session <SESSION-NAME>
nx9500-6C8809(config-profile-default-nx5500)#l2tpv3 manual-session test nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#
nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#? L2tpv3 Manual Session Mode commands: local-cookie The local cookie for the session local-ip-address Configure the IP address for tunnel. If not specified, tunnel source ip address would be chosen automatically based on the tunnel peer ip address local-session-id Local session id for the session mtu Configure the mtu size for the tunnel no Negate a command or set its defaults peer Configure L2TPv3 manual session peer remote-cookie The remote cookie for the session remote-session-id Remote session id for the session traffic-source Traffic that is tunneled clrscr Clears the display screen commit Commit all changes made in this session end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile default-nx5500-l2tpv3-manual-session-test)#
| Command | Description |
| local-cookie | Configures the manual session's local cookie field size |
| local-ip-address | Configures the manual session's local source IP address |
| local-session-id | Configures the manual session's local session ID |
| mtu | Configures the MTU size for the manual session tunnel |
| peer | Configures the manual session's peers |
| remote-cookie | Configures the remote cookie for the manual session |
| remote-session-id | Configures the manual session's remote session ID |
| traffic-source | Configures the traffic source tunneled by the manual session |
| no (l2tpv3-tunnel-config-mode-command) | Negates or reverts L2TPV3 manual session commands to default |
Section contents:
