ip (wlan-config-mode)
- Access
Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8533.
- Service Platforms: NX5500, NX7500, NX9500, NX9600
Syntax
ip [arp|dhcp]
ip arp [header-mismatch-validation|trust]
ip dhcp trust
Parameters
| ip arp | Configures the IP settings for ARP packets |
| header-mismatch-validation | Verifies mismatch of source MAC address in the ARP and Ethernet headers. This option is enabled by default. |
| trust | Sets ARP responses as trusted for a WLAN/range. This option is disabled by default. |
ip dhcp trust
| ip dhcp | Configures the IP settings for DHCP packets |
| trust | Sets DHCP responses as trusted for a WLAN/range. This option is disabled by default. |
nx9500-6C8809(config-wlan-test)#ip dhcp trust
nx9500-6C8809(config-wlan-test)#show context
wlan test
description TestWLAN
ssid test
bridging-mode local
encryption-type tkip-ccmp
authentication-type eap
accounting syslog host 172.16.10.4 port 2
data-rates 2.4GHz gn
client-load-balancing probe-req-intvl 5ghz 5
client-load-balancing band-discovery-intvl 2
captive-portal-enforcement fall-back
ip dhcp trust
acl exceed-rate wireless-client-denied-traffic 20 disassociate
enforce-dhcp
broadcast-dhcp validate-offer
http-analyze controller
Related Commands
| no (wlan-config-mode) | Resets IP ARP or DHCP trust parameters to default. ARP trust is disabled, ARP mismatch verification is enabled, or DHCP trust is disabled. |
