option (dhcpv6-pool-config)
Configures this DHCPv6 pool‘s raw DHCPv6 options. This is the vendor-specific option used in this DHCPv6 pool.
Access
Points: AP3000 /X, AP5010 , AP310i/e , AP410i/e , AP505i , AP510i , AP510e , AP560i , AP7602 , AP7612 , AP7622 , AP7632 , AP7662 , AP8163 , AP8533 . Service Platforms: NX5500, NX7500, NX9500, NX9600 Virtual Platforms : CX9000, VX9000
Syntax
option <OPTION-NAME> [<DHCPv6-OPTION-IP>|<DHCPv6-OPTION-ASCII>]
Parameters
<OPTION-NAME> Sets the name of the DHCPv6 option <DHCPv6-OPTION-IP> Sets DHCPv6 option as an IPv6 address <DHCPv6-OPTION-ASCII> Sets DHCPv6 option as an ASCII string
Usage Guidelines
An option name in ASCII format accepts backslash (\) as an input but is not displayed in the output. Use the command to view the output. Use a double backslash to represent a single backslash.
nx9500-6C8809 (config-dhcpv6-server-policy-test-pool-DHCPv6Pool1)#option DHCPv6Pool1Option 60
nx9500-6C8809 (config-dhcpv6-server-policy-test-pool-DHCPv6Pool1)#show context
dhcpv6-pool DHCPv6Pool1
network 2002::/64
domain-name TechPubs
dns-server 2002::1
