no (route-map-config-mode-command)
Removes this route-map settings or reverts them to default values
Syntax
no [default-next-hop|fallback|mark|match|next-hop]
Parameters
no <PARAMETERS>
no <PARAMETERS>Removes this route-map settings or reverts them to default values, based on the parameters passed
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
The following example shows the route-map ‘1‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#show context
 route-map 1
  match incoming-interface pppoe1
  next-hop vlan1
  default-next-hop wwan1
  mark ip dscp 7
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#no default-next-hop
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#no next-hop
The following example shows the route-map ‘1‘ settings after the ‘no‘ commands are executed:
 route-map 1
  mark ip dscp 7
