AP505i is a next generation, enterprise-class 802.11ax access point. The “i” in AP505i indicates that it comes with internal antennas. The AP505i can be used in stadiums, public venues such as hospitals and hotels, retail industry, and educational institutions. The 802.11ax technology supports more users and internet of things (IoT) devices.
Radios: 2 radios (one band locked at 2.4 GHz and the other band at 5 GHz); 1 IoT radio (2.4 GHz)
Console port: RJ45
Two Ethernet ports:
GE1 - 10/100/1000/2500 Mbps auto-negotiation Ethernet port, RJ45, with PoE In
GE2 - 10/100/1000 Mbps auto-negotiation Ethernet port, RJ45, with NO PoE
LEDs: 6 LEDs; all LEDs will be on during reset
One reset button
Power: PoE 802.3at; 12VDC external power in connector
Antennas:
Eight WiFi internal antennas
One BLE internal antenna
For more information on the 802.11ax access points, refer to their respective installation guides.
