dfs-rehome
interface-config-radio-instance
Reverts to configured home channel once the DFS (Dynamic Frequency Selection) evacuation period expires
This option is applicable only if the radio‘s RF mode is set to ‘5GHz-wlan‘.
Syntax
dfs-rehome {holdtime <30-3600>}
Parameters
dfs-rehome {holdtime <30-3600>}Enables the radio to revert to the configured home channel once the DFS evacuation period expires
  • holdtime – Optional. Specifies the duration, in minutes, to stay in the new channel
    • <30-3600> – Specify the holdtime from 30 - 3600 minutes. The default is 90 minutes.
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#dfs-rehome holdtime 500
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
Related Commands
no (radio-interface-config-command)Stays on DFS elected channel after evacuation period expires
