The AP5010 is a high-performance 802.11ax Wi-Fi 6E, 6 GHz, 5 GHz band, and 2.4 GHz
band access point designed for high-density indoor environments. The access point
supports IEEE 802.11ax Orthogonal Frequency-Division Multiple Access (OFDMA)
multi-user access.
The access point can be installed indoors on a ceiling rail, on a nonstandard
ceiling, or on a wall.
One multicolor LED status
light
One light sensor located at the
top of the device
Two Ethernet ports - Eth0 and
Eth1
Ethernet ports (Eth0 and Eth1) automatically negotiate full-duplex
connections with the connecting device.
Eth0 is 5/2.5/1GE/100
with Power over Ethernet (PoE)
Eth1 is 2.5/1GE/100
with PoE power sourcing equipment (PSE)
These ports are auto-sensing and adjust to straight-through and
crossover standard Cat6 or better Ethernet cables automatically. The access
point receives power through an Ethernet connection to the ETH0 port from
PSE that is compatible with the 802.3bt and 802.3at standards.
One USB port
Use the USB port
to connect USB-based beacons such as iBeacon and Internet of Things (IoT)
devices. Remove the protective cover to access the USB port.
One micro USB console port
One reset button
One Kensington lock
The best
practice is to use Kensington locks for locking the device.
