The following table summarizes the Passpoint Policy configuration mode commands:
Command |
Description |
| 3gpp |
Configures a 3gpp (3rd Generation Partnership Project) PLMN (Public Land Mobile Network) ID |
| access-network-type |
Configures the access network type element in this hotspot |
| connection-capability |
Configures the connection capability element in this passpoint policy |
| domain-name |
Configures the RF Domains to which this hotspot is applicable |
| hessid |
Configures the HESSID (Homogeneous Extended Service Set Identifier) for a specified hotspot zone |
| internet |
Advertises the availability of Internet access in this hotspot |
| ip-address-type |
Advertises the IP address type used in this hotspot. |
| nai-realm |
Configures a NAI (Network Access Identifier) realm name and enters its configuration mode |
| net-auth-type |
Configures the network authentication type used in this hotspot |
| operator |
Configures the operator friendly name for this hotspot |
| osu | Configures an OSU (online sign up) SSID/provider and enters its configuration mode |
| roam-consortium |
Configures the list of Roaming Consortium OIs (Organization Identifiers) supported on this hotspot |
| venue |
Configures the venue group and type for this passpoint policy |
| wan-metrics |
Configures the WAN performance metrics for this hotspot |
| no |
Removes or reverts passpoint policy configuration |
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands .Section contents:
