show t5 [boot|clock|cpe|interface|mac|system|temperature|uptime|version|
wireless] {on <T5-DEVICE-NAME>}
show t5 [boot|clock|system|temperature|uptime|version]
show t5 cpe [address|boot|ether port status|led|reset|system|uptime|version]
show t5 interface [dsl|fe|ge|radio]
show t5 interface [dsl|fe|ge] [counter|description|errors|status|utilization]
show t5 interface dsl custom [avg|dses|dsses|peak|uses|usses]
show t5 interface radio [stats|status|wlam-map]
show t5 mac table [filter name [dsl<1-24>|ge <1-2>|vlan <1-4094>|wlan <1-24>]
show t5 wireless [client|wlan]
show t5 wireless client {filter name [association-status|authentication-status|
bss|mac-address|retry-percentage|rssi-value]} {on <T5-DEVICE-NAME>}
show t5 wireless wlan counters [qos|rate|size]
Parameters
t5
Displays adopted T5 controller statistics
boot
Displays the T5 device‘s boot details. Use this option to
view the primary and secondary image files available to use for booting up.
clock
Displays the T5 controller‘s system time, as reported from
the controller itself or its remote NTP time resource
system
Displays T5 controller‘s system information, which
includes the T5 controller‘s hostname, MAC address, RF Domain,
system clock, uptime
temperature
Displays T5 controller‘s current temperature
uptime
Displays the T5 controller‘s uptime (the time it has been
actively deployed and operational)
version
Displays the T5 controller‘s primary and secondary
firmware images
on <T5-DEVICE-NAME>
Optional. Executes the command on a specified T5 device
<T5-DEVICE-NAME> – Specify the T5 device‘s
hostname. An error message is displayed if no T5 device
name is specified.
t5
cpe
Displays the T5 controller managed Customer Premises
Equipment (CPE) statistics based on the parameters passed. Use this command to
verify each CPE address credentials and whether currently disconnected or ready for
radio coverage area support.
address
Displays each linked CPE's current IP address used as its network
identifier
boot
Displays the primary and secondary firmware versions available to each CPE,
along with status of the most recent upgrade operation details
ether port status
Displays Ethernet port status
led
Displays whether the CPEs currently have their LEDs enabled or disabled. In
places like hospitals, its not uncommon for access points to be operational, but
their LEDs off as to not disturb patients.
reset
Displays the number times a CPE has been reset
system
Displays device hardware and SKU information for each CPE. Use this information
to assess whether a controller is managing the correct CPE devices out of the total
number of CPEs available.
uptime
Displays the time each CPE device has been actively deployed and
operational
version
Displays the application and boot versions utilized by the CPE devices
on <T5-DEVICE-NAME>
name is specified.
t5
interface
Displays T5 interface-related statistics based on the
interface selected
Select the interface type. The options are: dsl,
fe, and ge.
dsl – Displays Digital
Subscriber Line (DSL) interface related information
fe – Displays Fast Ethernet
(FE) interface related information
ge – Displays Gigabit
Ethernet (GE) interface related information
The system displays the following information for the DSL, GE, and FE
ports:
counter – Displays the
following:
Number of octets (bytes)
received and transmitted on this port
Number of data packets
Number of flow control
(layer 2) packets received and transmitted on this port
description – Displays the
following:
The selected port‘s
name
The numeric index
assignable to each port
The 64 character maximum,
unique, administrator-assigned description to each port
errors – Displays the
following DSL interface related errors:
The name of the DSL
utilized by each T5 controller connected CPE
device
The number of FECs
detected in the downstream direction. Forward Error Correction
(FEC) or channel coding is used for controlling errors over unreliable
or noisy communication channels.
The number of CPE DSL
coding violations (badly coded packets) detected in the downstream
direction.
The number of FECs
detected in the upstream direction.
coding violations (badly coded packets) detected in the upstream
direction.
status – Displays the
following:
The selected port‘s
name
Whether the port is
currently up or down as a T5 controller transmit and
receive resource
The port's current speed
in MB
Whether pause packet
utilization is currently off or on for the selected port
Whether each listed port
is enabled or disabled by the administrator
utilization – Displays the
following:
The selected port‘s
name
The port‘s receive and
transmit data rates (in Kbps)
The packet per second
port receive and transmit rates (p/s)
Each port's receive and
transmit direction utilization as a percentage of the total transmit
bandwidth available.
on <T5-DEVICE-NAME>
name is specified.
t5
interface
interface selected
dsl
Selects A T5 controller‘s DSL interface.
A T5 controller uses the operating system to manage its connected
radio devices, as opposed to the WiNG
operating used by RFS controllers and NX service platforms. However, a T5 controller, once enabled as a supported external device, can
provide data to WiNG to assist in a
T5‘s management within a WiNG supported subnet populated by both
types of devices. The CPEs are the T5 controller managed
radio devices using the operating system. These CPEs use a DSL as their high speed
Internet access mechanism using the CPE‘s physical wallplate connection and phone
jack.
Displays following custom CPE DSL data:
avg – Each DSL's average
response time in microseconds
dses – The number of seconds
downstream DSL transmissions were negatively impacted by code violations.
dsses – The number of seconds
downstream DSL transmissions were severely negatively impacted by code
violations.
peak – Each DSL's maximum (best
to date since the screen was refreshed) response time in microseconds.
uses – The number of seconds
upstream DSL transmissions were negatively impacted by code violations.
usses – The number of seconds
upstream DLS transmissions were severely negatively impacted by code
violations.
on <T5-DEVICE-NAME>
name is specified.
show t5 interface radio [stats|status|wlam-map] {on <T5-DEVICE-NAME>}
t5
interface
interface selected
radio [stats|status| wlan-map]
Displays following radio interface related
information:
stats – Displays T5 radio interface statistics. A T5
controller uses the operating system to manage its connected radio devices, as
opposed to the WiNG operating used
controller, once enabled as a supported external device, can provide data to WiNG to assist in a T5‘s management within a WiNG supported subnet populated by both types of devices. The CPEs are
the T5 controller managed radio devices using the operating
system. Use this option to view the following:
name – The administrator
assigned name of each listed CPE radio as its unique identifier
Rx (Kbps) – The listed CPE
radio's receive data rate (in Kbps). Use this information to assess RF
activity versus other T5 managed CPE radios in the same
radio coverage area.
Rx Octets – The number of
octets (bytes) received with no errors by the listed T5
controller managed CPE radio.
Rx Packets – The number of
data packets received for the listed T5 managed CPE
radio since this screen was last refreshed.
Tx (Kbps) – The listed CPE
radio's transmit data rate (in Kbps). Use this information to assess RF
Tx Octets – Displays the
number of octets (bytes) transmitted with no errors by the listed T5 controller managed CPE radio.
Tx Packets – The number of
data packets transmitted from the listed T5 managed CPE
status – Displays T5 radio interface status information
assigned name of each listed CPE radio as its unique identifier.
Operational status – The
radio interface‘s operational status (enabled/disabled).
mac – The T5 radio interface's MAC address.
transmit power – The T5 radio interface‘s transmit power.
Channel – The T5 radio interface‘s channel of operation.
wlan-map – Displays WLAN map
membership data for T5 controller managed CPE radio
devices. Use this option to view the following:
status – Whether a CPE
radio is currently enabled or disabled as a radio resource for the WLAN(s)
the CPE radio has been mapped to.
wlan-radio-mapping – The
managed WLAN(s) each listed radio has been mapped to.
on <T5-DEVICE-NAME>
name is specified.
t5
mac table [dsl<1-24>|ge <1-2>| vlan <1-4094>|
wlan <1-24>]
Displays T5 MAC address table. The T5
MAC table displays a dynamic list of MAC addresses learned by the T5 controller over its ethernet interfaces. Use this information to identify
devices and the interfaces on which they can be found.
Use the following
additional filters to filter on the basis of the VLAN or DSL interface:
dsl <1-24> – Filters
information on the basis of the selected DSL port
ge <1-2> – Filters
information on the basis of the selected GE port
vlan <1-4094 – Filters
information on the basis of the selected VLAN port
wlan <1-24> – Filters
on the basis of the selected CPE
on <T5-DEVICE-NAME>
name is specified.
show t5 wireless client {filter name [association-status|authentication-status|bss|
t5
wireless client
Displays the T5 wireless client and WLAN related
statistics
client – Displays read-only
device information for wireless clients associated with the selected T5 controller and its connected CPE device radios. Use this
information to assess if configuration changes are required to improve client
performance.
Use the additional filters available to view specific client-related
information. The options are:
association-status
bss
retry-percentage
rssi-value
on <T5-DEVICE-NAME>
name is specified.
show t5 wireless wlan counters [qos|rate|size] {on <T5-DEVICE-NAME>}
t5
wireless wlan [qos|rate|size]
Displays the T5 wireless WLAN related statistics
wlan – Displays following T5 controller traffic counter statistics:
qos – Displays T5 controller WLAN QoS utilization. Displays the number
of background (low priority) and best-effort packets received and
transmitted on each listed T5 controller managed
WLANs
rates – Displays T5 controller's WLAN utilization data rate statistics
Lists the number of
data packets received and transmitted in the WLAN that have been
relegated to a 1 Mbps data rate
Lists the number of
data packets received and transmitted in the WLAN by T5 controller connected devices at 54Mbps
size – Displays the number
of data packets received and transmitted, in each listed WLAN, greater than
1024 bytes
on <T5-DEVICE-NAME>
name is specified.
The following examples are for show commands executed on the ‘t5-ED7C6C‘ controller adopted
by the ‘nx9500-6C8809‘ wireless controller:
nx9500-6C8809(config)#show t5 version on t5-ED7C6C
Bootloader Version: 5.4.2.0-010R
Application Version: 5.4.2.0-010R
nx9500-6C8809(config)#show t5 system on t5-ED7C6C
Serial Number 14213522400004
SKU TS-0524-WR
Hardware Rev 5
Mac Address B4-C7-99-ED-7C-6C
Description 24-port PowerBroadband VDSL2 Switch Version 5.4.2.0-010R
Contact NULL
Name t5-ED7C6C
Location NULL
nx9500-6C8809(config)#show t5 clock on t5-ED7C6C
Time 6-6-2017 17:14:30 UTC
nx9500-6C8809(config)#show t5 uptime on t5-ED7C6C
Up Time 0 days 1 day, 3:19:43
nx9500-6C8809(config)#show t5 temperature on t5-ED7C6C
============ Temperature ============
INDEX CURRENT (C) FANS @ FULL SPEED (C) FANS @ VARIABLE SPEED (C)
1 39 70 60
nx9500-6C8809(config)#show t5 cpe address on t5-ED7C6C
DEVICE STATUS IP ADDRESS MAC ADDRESS
cpe1 ready 192.168.13.32 00-C0-23-69-80-CD
cpe2 ready 192.168.13.33 74-6F-F7-40-16-62
cpe3 disconnected 0.0.0.0 00-00-00-00-00-00
cpe4 disconnected 0.0.0.0 00-00-00-00-00-00
cpe5 disconnected 0.0.0.0 00-00-00-00-00-00
--More--
nx9500-6C8809(config)#show t5 cpe led on t5-ED7C6C
DEVICE LED STATUS
cpe1 enable
cpe2 enable
cpe3 enable
cpe4 enable
cpe5 enable
--More--
