Configures T5 PowerBroadband security settings. A T5 controller uses the IPX operating system to manage its connected radio devices, as opposed to the WiNG operating system used by wireless controllers and service platforms. However, a T5 controller, once enabled as a supported external device, can provide data to WiNG to assist in a T5‘s management within the WiNG supported subnet populated by both types of devices. The CPEs are the T5 controller managed radio devices using the IPX operating system. These CPEs use a DSL as their high speed Internet access mechanism using the CPE‘s physical wallplate connection and phone jack.
This setting is applicable only when this WLAN supports T5 controllers and their connected CPEs.
Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Configures the T5 WLAN security type as static-wep
encryption-type [wep128|wep64]
Applies one of the following encryption algorithms to the T5 support WLAN configuration: WEP64 or WEP128
hex <STRING>
Configures the hex password (used to derive the security key)
<STRING> – Specify the hex password (should not exceed the 10 - 26 characters).
passphrase <STRING>
Configures the passphrase shared by both transmitting and receiving authenticators
<STRING> – Specify the passphrase. It could either be an alphanumeric string of 8 to 63 ASCII characters or 64 HEX characters. The alphanumeric string allows character spaces. This string is converted to a numeric value. Configuring a passphrase saves you the need to create a 256-bit key each time keys are generated.
t5-security [wpa-enterprise|wpa-personal] encryption-type [ccmp|tkip|tkip-ccmp]
version [mixed|wpa|wpa2]
t5-security [wpa-enterprise| wpa-personal]
Configures the T5 WLAN security type as: wpa-enterprise OR wpa-personal
The following parameters are common to the wpa-enterprise and wpa-personal keywords:
[ccmp|tkip|tkip-ccmp] – Applies one of the following encryption algorithms to the T5 support WLAN configuration: CCMP, TKIP, or TKIP-CCMP.
version – Applies one of the following encryption schemes to the T5 support WLAN configuration: WPA, WPA2, or mixed.
nx9500-6C8809(config-wlan-test)#t5-security wpa-enterprise encryption-type ccmp version wpa
nx9500-6C8809(config-wlan-test)#show context
wlan test
ssid test
bridging-mode local
encryption-type none
authentication-type none
t5-client-isolation
