Advertisement messages are also sent to indicate a change in link layer address for a node on the local link. With such a change, the multicast address becomes the destination address for advertisement messages.
ipv6-router-advertisement-policy <POLICY-NAME>
| <POLICY-NAME> | Specify an IPv6 RA policy name. If a policy with the specified name does not exist, it is created. |
rfs4000-229D58(config)#ipv6-router-advertisement-policy test rfs4000-229D58(config-ipv6-radv-policy-test)#? IPv6 Router Advertisement Policy Mode commands: advertise Option to advertise in router advertisement assist-neighbor-discovery Send the Source Link Layer address option in Router Advertisement to assist in neighbor discovery check-ra-consistency Check if the parameters advertised by other routers on the link are in conflict with those configured on this router. Conflicts are logged. dns-server DNS Server domain-name Configure domain-name managed-config-flag Set the managed-address-configuration flag in Router Advertisements. When set, it indicates that the addresses are available via DHCPv6 nd-reachable-time Time that a node assumes a neighbor is reachable after having received a reachability confirmation no Negate a command or set its defaults ns-interval Time between retransmitted Neighbor Solicitation messages other-config-flag Set the other-configuration flag in Router Advertisememts. When set, it indicates that other configuration information is available via DHCPv6. ra Router Advertisements router-lifetime Lifetime associated with the default router router-preference Preference of this router over other routers unicast-solicited-advertisement Unicast the solicited Router Advertisements clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal rfs4000-229D58(config-ipv6-radv-policy-test)#
| no | Removes the specified IPv6 RA policy |
Section contents:
