Configures an LACP-enabled peer‘s system priority value. LACP uses this system priority value along with the peer‘s MAC address to form the system ID. In a LAG, the peer with the lower system ID initiates LACP negotiations with another peer. In scenarios, where both peers have the same system-priority value assigned, the peer with the lower MAC gets precedence.
Service Platforms —
Syntax
lacp system-priority <1-65535>
Parameters
<1-65535>
Configures the LACP system priority value
<1-65535> – Specify a value from 1 - 65535. Lower the value, higher is the priority. Therefore, ‘1‘ and ‘65535‘ indicate highest and lowest system-priority values respectively. The default value is 32768.
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#lacp system-priority 1
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#show context include-factory | include lacp
lacp-channel-group 1 mode active
lacp port-priority 2
