Configures a TACACS authentication server. Up to 2 TACACS servers can be
configured
<1-2> – Specify
the TACACS server index from 1 - 2.
host <IP/HOSTNAME>
Sets the TACACS server‘s IP address or hostname
secret [0 <SECRET>| 2 <SECRET>| <SECRET>]
Configures the secret key used to authenticate with the TACACS server
0 <SECRET> –
Configures a clear text secret
2 <SECRET> –
Configures an encrypted secret
<SECRET> –
Specify the secret key. The shared key should not exceed 127
characters.
port <1-65535>
Optional. Specifies the port used to connect to the TACACS server
<1-65535> –
Specify a value for the TCP authentication port from 1 - 65535. The
default port is 49.
authentication server <1-2> retry-timeout-factor <50-200>
server <1-2>
configured
<1-2> – Specify
Configures timeout scaling between two consecutive TACACS authentication
retries
<50-200> –
Specify the scaling factor from 50 - 200. The default is 100.
A value of 100 indicates the interval between consecutive retires
remains the same irrespective of the number of retries.
A value
lesser than 100 indicates the interval between consecutive retries
reduces with each successive retry.
A value greater than 100
indicates the interval between consecutive retries increases with each
successive retry.
authentication server <1-2> timeout <3-60> {attempts <1-10>}
server <1-2>
configured
<1-2> – Specify
the TACACS server index from 1- 2.
timeout <3-60>
Configures the timeout, in seconds, for each request sent to the TACACS
server. This is the time allowed to elapse before another request is sent to
the TACACS server. If a response is received from the TACACS server within
this time, no retry is attempted.
<3-60> – Specify
a value from 3- 60 seconds. The default is 3 seconds.
attempts <1-10>
Optional. Indicates the number of retry attempts to make before giving
up
<1-10> – Specify
a value from 1 -10. The default is 3.
authentication service <SERVICE-NAME> {protocol <AUTHENTICATION-PROTO-NAME>}
Configures the TACACS authentication service name
protocol <AUTHENTICATION- PROTO-NAME>
Optional. Specify the authentication protocol used with this TACACS
policy
