In addition to the above, PBR policies facilitate the provisioning of preferential service to specific traffic. PBR minimally provides the following:
Use the (config) instance to configure router-policy commands. To navigate to the (config-routing-policy mode) instance, use the following commands:
<DEVICE>(config)#routing-policy <ROUTING-POLICY-NAME>
nx9500-6C8809(config)#routing-policy testpolicy nx9500-6C8809(config-routing-policy-testpolicy)#? Routing Policy Mode commands: apply-to-local-packets Use Policy Based Routing for packets generated by the device logging Enable logging for this Route Map no Negate a command or set its defaults route-map Create a Route Map use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-routing-policy-testpolicy)#
Section contents:
