cert-key-size
Configures the size of the key associated with a certificate request
- Access
Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8533.
- Service Platforms: NX5500, NX7500, NX9500, NX9600
Syntax
cert-key-size [2048|3072|4096]
Parameters
| cert-key-size [2048|3072|4096] | Configures the certificate request key size. The options are:- 2048 – Sets the key size to 2048 bits. This is the default setting.
- 3072 – Sets the key size to 3072 bits
- 4096 – Sets the key size to 4096 bits
nx9500-6C8809(config-cmp-policy-test)#cert-key-size 3072
nx9500-6C8809(config-cmp-policy-test)#show context
crypto-cmp-policy test
cert-key-size 3072
ca-server primary host 192.168.8.74 port 8 path cmp
Related Commands
| no | Reverts the certificate request key size to default (2048 bits) |
