EX3500 devices (EX3524 and EX3548) are layer 2 Gigabit Ethernet switches with either 24 or 48 10/100/1000-BASE-T ports, and four SFP transceiver slots for fiber connectivity. Each 10/100/1000 Mbps port supports both the IEEE 802.3af and IEEE 802.3at-2009 PoE standards. An EX3500 switch has an SNMP-based management agent that provides both in-band and out-of-band management access. The EX3500 switch utilizes an embedded HTTP Web agent and CLI, which in spite of being different from that of the WiNG operating system provides WiNG controllers PoE and port management resources.
Going forward NX7500, NX9500, and NX9600 WiNG managed series service platforms and VMs can discover, adopt, and partially manage EX3500 series Ethernet switches without modifying the proprietary operating system running the EX3500 switches. The WiNG service platforms utilize standardized interfaces to push configuration files to the EX3500 switches, and maintain a translation layer, understood by the EX3500 switch, for statistics retrieval.
WiNG can partially manage an EX3500 without using DHCP option 193, provided the EX3500 is directly configured to specify the IPv4 addresses of potential WiNG adopters. To identify the potential WiNG adopter, in the EX3500‘s device configuration mode specify the adopter IPv4 address using the controller > host > <IP-ADDRESS> command. WiNG service platforms leave the proprietary operating system running the EX3500 switches unmodified, and partially manage them utilizing standardized WiNG interfaces. WiNG service platforms use a translation layer to communicate with the EX3500.
ex3500-management-policy <POLICY-NAME>
| <POLICY-NAME> | Specify the EX3500 management policy name. If the policy does not exist, it is created. |
nx9500-6C8809(config)#ex3500-management-policy test nx9500-6C8809(config-ex3500-management-policy-test)#? nx9500-6C8809_Management Mode commands: enable Modifies enable password parameters http Hyper Text Terminal Protocol (HTTP) memory Memory utilization no Negate a command or set its defaults process-cpu Process-cpu utilization snmp-server Enable SNMP server configuration ssh Secure Shell server connections username Login TACACS server port clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-ex3500-management-policy-test)#
| no | Removes this EX3500 management policy |
Section contents:
