ap-id (iot-device-type-imagotag-policy)
Configures an Access Point (AP) ID, allowing the SES-Imagotag server to identify individual Imagotag-enabled ExtremeWireless WiNG APs.
On the Imagotag server, configure the ExtremeWireless WiNG AP's ID. This enables the server identify the AP. Use the show iot-device-type-imagotag status command to obtain the AP's ID. Refer to the Imagotag server configuration guide for more information.
Supported on the following platforms:
Syntax
ap-id <210000-219999>
Parameters
ap-id <210000-219999>Enter a value in the range 210000 – 219999 that uniquely identifies the AP to the SES-Imagotag server.
vx9000-AA3AED(config-iot-device-type-imagotag-policy-CaroTest)#ap-id ?
  <210000-219999>  AP ID
vx9000-AA3AED(config-iot-device-type-imagotag-policy-CaroTest)#ap-id 210001
vx9000-AA3AED(config-iot-device-type-imagotag-policy-CaroTest)#show context
 iot-device-type-imagotag-policy CaroTest
  ap-id 210001
vx9000-AA3AED(config-iot-device-type-imagotag-policy-CaroTest)#no ap-id
Related Commands
no (iot-device-type-imagotag-policy)Removes the configured ap-id.
