service
Service commands are used to view and manage configurations. The service commands and their corresponding parameters vary from mode to mode. The User Exec mode and Priv Exec mode commands provide same functionalities with a few minor changes. The Global Config service command sets the size of history files. It also enables viewing the current mode's CLI tree.
Syntax (User Exec Mode)
Service Commands - Intro
service [block-adopter-config-update|clear|cli-tables-skin|cluster|database|
delete-offline-aps|eguest|force-send-config|force-update-vm-stats|guest-registration|
load-balancing|load-ssh-authorized-keys|locator|nsight|radio|radius|
request-full-config-from-adopter|set|show|smart-rf|ssm|snmp|syslog|wireless]
service [block-adopter-config-update|request-full-config-from-adopter]
service eguest [remove-data|restore]
service eguest remove-data [deleted-devices|offline-for days <0-999>
{time <HH:MM:SS>}]
service eguest restore factory-default
service clear [adoption|captive-portal-page-upload|command-history|device-upgrade|
diag|dpi|file-sync|noc|reboot-history|unsanctioned|upgrade-history|virtual-machine-history|
web-filter|wireless|xpath]
service clear adoption history {on <DEVICE-NAME>}
service clear device-upgrade history {on <DOMAIN-NAME>}
service clear dpi [all|app|app-category] stats {on <DEVICE-OR-DOMAIN-NAME>}
service clear diag pkts
service clear file-sync history {on <DOMAIN-NAME>}
service clear captive-portal-page-upload history {on <DOMAIN-NAME>}
service clear [command-history|reboot-history|upgrade-history|virtual-machine-history]
{on <DEVICE-NAME>}
service clear noc statistics
service clear unsanctioned aps {on <DEVICE-OR-DOMAIN-NAME>}
service clear web-filter cache {on <DEVICE-NAME>}
service clear wireless [ap|client|controller-mobility-database|dns-cache|radio|wlan]
service clear wireless controller-mobility-database
service clear wireless [ap|client] statistics {<MAC>} {(on <DEVICE-OR-DOMAIN-NAME>)}
service clear wireless dns-cache on {(on <DEVICE-OR-DOMAIN-NAME)}
service clear wireless radio statistics {<MAC/HOSTNAME>} {<1-3>}
service clear wireless wlan statistics {<WLAN-NAME>} {(on <DEVICE-OR-DOMAIN-NAME)}
service clear xpath requests {<1-100000>}
service cli-tables-skin [ansi|hashes|minimal|none|percent|stars|thick|thin|utf-8]
{grid}
service cluster force [active|configured-state|standby]
service database [authentication|start-shell]
service database authentication [create-user|delete-user]
service database authentication create-user username <USER-NAME> password <PASSWORD>
service database authentication delete-user username <USER-NAME>
service database start-shell
service delete-offline-aps [all|offline-for]
service delete-offline-aps offline-for days <0-999> {time <TIME>}
service force-send-config {on <DEVICE-OR-DOMAIN-NAME>}
service force-update-vm-stats {on <DEVICE-NAME>}
service guest-registration [backup|delete|export|import]
service guest-registration backup [delete|restore]
service guest-registration delete [all|email <EMAIL-ADD>|group <RAD-GROUP-NAME>|
mac <MAC>|mobile <MOBILE-NUMBER>|name <CLIENT-FULL-NAME>|non-social|
offline-for days <1-999>|otp-incomplete-for days <1-999>|social [facebook|google]|
wlan <WLAN-NAME>]
service guest-registration export format [csv|json] <DEST-URL>
{(rfdomain <DOMAIN-NAME>|time [1-Day|1-Month|1-Week|2-Hours|30-Mins|5-Hours|all]| wlan <WLAN-NAME>)}
service guest-registration import format <JSON> <SOURCE-URL>
service load-balancing clear-client-capability [<MAC>|all] {on <DEVICE-NAME>}
service load-ssh-authorized-keys <PUBLIC-KEY> {on <DEVICE-NAME>}
service locator {<1-60>} {(on <DEVICE-NAME>)}
service nsight clear-offline [all|offline-for days <0-999> {time <TIME>}]
service radio <1-3> [adaptivity|channel-switch|dfs]
service radio <1-3> adaptivity
service radio <1-3> channel-switch <36-196> [160|20|40|80]
service radio <1-3> dfs simulator-radar [extension|primary]
service radius test [<IP>|<HOSTNAME>] [<WORD>|<PORT>]
service radius test [<IP>|<HOSTNAME>] <WORD> <USERNAME> <PASSWORD>
{wlan <WLAN-NAME> ssid <SSID>} {(on <DEVICE-NAME>)}
service radius test [<IP>|<HOSTNAME>] port <1024-65535> <WORD> <USERNAME> <PASSWORD>
service set validation-mode [full|partial] {on <DEVICE-NAME>}
service show [block-adopter-config-update|captive-portal|cli|client-identity-defaults|
command-history|configuration-revision|crash-info|dhcp-lease|diag|fast-switching|fib|
fib6|guest-registration|info|ip-access-list|mac-vendor|mem|mint|noc|nsight|pm|process|
reboot-history|rf-domain-manager|sites|snmp|ssh-authorized-keys|startup-log|sysinfo|
top|upgrade-history|virtual-machine-history|watch-dog|wireless|xpath-history]
service show block-adopter-config-update
service show captive-portal [log-internal|servers|user-cache]
service show captive-portal log-internal
service show captive-portal [servers|user-cache] {on <DEVICE-NAME>}
service show [cli|client-identity-defaults|configuration-revision|mac-vendor <OUI/MAC>|
noc diag|snmp session|xpath-history]
service show [command-history|crash-info|info|mem|process|reboot-history|startup-log|
ssh-authorized-keys|sysinfo|top|upgrade-history|watchdog] {on <DEVICE-NAME>}
service show ip-access-list wlan <WLAN-NAME> status {detail} {on <DEVICE-OR-DOMAIN-NAME>}
service show dhcp-lease {<INTERFACE-NAME>|pppoe1|vlan <1-4094>|wwan1} (on <DEVICE-NAME>)}
service show diag [fds|led-status|pkts|psu|stats]
service show diag [fds|pkts]
service show diag [led-status|psu|stats] {on <DEVICE-NAME>}
service show fast-switching {on <DEVICE-NAME>}
service show [fib|fib6] {table-id <0-255>}
service show guest-registration [export-status|import-status|restore-status]
service show mint [adopted-devices {on <DEVICE-NAME>}|ports]
service show pm {history} {(on <DEVICE-NAME>)}
service show rf-domain-manager [diag|info] {<MAC/HOSTNAME>} {(on <DEVICE-OR-DOMAIN-NAME>)}
service show sites
service show virtual-machine-history {on <DEVICE-NAME>}
service show wireless [aaa-stats|adaptivity-status|client|config-internal|
credential-cache|dns-cache|log-internal|meshpoint|neighbors|radar-status|
radio-internal|reference|stats-client|vlan-usage]
service show wireless [aaa-stats|adaptivity-status|credential-cache|dns-cache|
radar-status|vlan-usage] {on <DEVICE-NAME>}
service show wireless [config-internal|log-internal|neighbors]
service show wireless [client|meshpoint neighbor] proc [info|stats] {<MAC>} {{on <DEVICE-OR-DOMAIN-NAME>)}
service show wireless radio-internal [radio1|radio2] <LINE>
service show wireless reference [channels|frame|handshake|mcs-rates|reason-codes|
status-codes]
service show wireless stats-client diag {<MAC/HOSTNAME>} {(on <DEVICE-OR-DOMAIN-NAME>)}
service smart-rf [clear-config|clear-history|clear-interfering-aps|save-config]
service smart-rf clear-config {<MAC>|<DEVICE-NAME>|on <DOMAIN-NAME>}
service smart-rf [clear-history||clear-interfering-aps|save-config] {on <DOMAIN-NAME>}
service snmp sysoid wing5
service ssm [dump-core-snapshot|trace]
service ssm trace pattern <WORD> {on <DEVICE-NAME>}
service syslog test {level [<0-7>|alerts|critical|debugging|emergencies|errors| informational|notifications|warnings]} {(on <DEVICE-NAME>)}
service wireless [client|dump-core-snapshot|meshpoint|qos|trace|unsanctioned|wips]
service wireless client [beacon-request|quiet-element|trigger-bss-transition|trigger-wnm]
service wireless client beacon-request <MAC> mode [active|passive|table]
ssid [<SSID>|any] channel-report [<CHANNEL-LIST>|none] {on <DEVICE-NAME>}
service wireless client trigger-bss-transition mac <MAC> {timeout <0-65535>} {url <URL>} {on <DEVICE-OR-DOMAIN-NAME>}
service wireless client trigger-wnm mac <MAC> type
[deauth-imminent|subscription-remediation] {uri <WORD>}
service wireless dump-core-snapshot
service wireless meshpoint zl <MESHPOINT-NAME> [on <DEVICE-NAME>]
{<ARGS>|timeout <1-65535>}
service wireless qos delete-tspec <MAC> tid <0-7>
service wireless trace pattern <WORD> {on <DEVICE-NAME>}
service wireless unsanctioned ap air-terminate <MAC> {on <DOMAIN-NAME>}
service wireless wips [clear-client-blacklist|clear-event-history|dump-managed-config]
service wireless wips clear-client-blacklist [all|mac <MAC>]
service wireless wips clear-event-history {on <DEVICE-OR-DOMAIN-NAME>}
Parameters (User Exec Mode)
block-adopter-config- updateBlocks the configuration updates pushed from the Network Operations Center (NOC) server to adopted devices
request-full-config-from- adopterConfigures a request for full configuration updates from the adopter device
In an hierarchically managed (HM) network devices are deployed in two levels. The first level consists of the NOC controllers. The second level consists of the site controllers that can be grouped to form clusters. The NOC controllers adopt and manage the site controllers. Access points within the network are adopted and managed by the site controllers. The adopted devices (Access Points and site controllers) are referred to as the adoptee. The devices adopting the adoptee are the ‘adopters‘.
clear adoption historyClears adoption history on this device and its adopted Access Points
on <DEVICE-NAME>Optional. Clears adoption history on a specified device
  • <DEVICE-NAME> – Specify the name of the AP, wireless controller, or service platform.
clear device-upgrade historyClears device upgrade history
on <DOMAIN-NAME>Optional. Clears all firmware upgrade history on a specified RF Domain
  • <DOMAIN-NAME> – Specify the RF Domain name.
clear diag pktsClears the looped packets queue logged by the dataplane. The dataplane logs up to 16 looped packets at a time in a separate queue, which has to be manually cleared to make space for new packet logging.
For more information on viewing logged looped packet information execute the service > show > diag > pkts command.
clear dpiClears Deep Packet Inspection (DPI) statistics
When enabled, DPI allows application and/or application category recognition. The DPI statistics are maintained by the system for every hit registered by the DPI engine.
[all|app|app-category] statsUse the following filter options to clear all or specific DPI statistics:
  • all – Clears all DPI related (application and app-category) statistics
  • app – Clears only application related statistics
  • app-category – Clears only app-category related statistics
on <DEVICE-OR-DOMAIN-NAME>Optional. Clears DPI statistics based on the parameters passed on a specified device or RF Domain
  • <DEVICE-OR-DOMAIN-NAME> – Specify the name of the access point, controller, service platform, or RF Domain.
clear file-sync historyClears client-bridge certificate synchronization statistics
When an AP 6522/AP 6562 access point is configured as a client bridge, the EAP-TLS X.509 (PKCS#12) certificate is synchronized between the staging-controller and adoptee AP 6522/AP 6562 client-bridge access points. This command allows you to clear client-bridge certificate synchronization statistics.
on <DOMAIN-NAME>Optional. Clears file synchronization history on all devices within a specified RF Domain
clear captive-portal-page- upload-historyClears captive portal page upload history
on <DOMAIN-NAME>Optional. Clears captive portal page upload history on a specified RF Domain
{on <DEVICE-NAME>}
clear [command-history| reboot-history| upgrade-history]Clears command history, reboot history, and/or device upgrade history
clear virtual-machine-historyClears virtual-machine history on the logged device or a specified device
This command is applicable only on the NX 95XX and NX 96XX series service platforms.
on <DEVICE-NAME>Optional. Clears history on a specified device
Note: When executing the clear virtual-machine-history command, provide the name of the service platform running the VMs.
clear noc statisticsClears NOC applicable statistics counters
clear unsanctioned apsClears the list of unsanctioned APs
on <DEVICE-OR-DOMAIN-NAME>Optional. Clears the list of unsanctioned APs on a specified device or RF Domain
  • <DEVICE-OR-DOMAIN-NAME> – Specify the name of the AP, wireless controller, service platform, or RF Domain.
service clear wireless [ap|client] {<MAC>} {(on <DEVICE-OR-DOMAIN-NAME>)}
clear wireless [ap|client] statisticsClears wireless statistics counters based on the parameters passed
  • ap statistics – Clears applicable AP statistics counters
  • client statistics – Clears applicable wireless client statistics counters
<MAC> {on <DEVICE-OR-DOMAIN-NAME>}The following keywords are common to the ‘ap' and ‘client' parameters:
  • <MAC> – Optional. Clears statistics counters for a specified AP or client. Specify the AP/client MAC address.
    • on <DEVICE-OR-DOMAIN-NAME> – Optional. Clears AP/client statistics counters on a specified device or RF Domain. Specify the name of the AP, wireless controller, service platform, or RF Domain.
clear wireless controller-mobility- databaseClears the controller assisted mobility database
clear web-filter cacheClears the cache used for Web filtering
on <DEVICE-NAME>Optional. Clears the Web filtering cache on a specified device
service clear wireless radio statistics {<MAC/HOSTNAME> {<1-3>}}
clear wireless radio statisticsClears applicable wireless radio statistics counters
<MAC/HOSTNAME> <1-3>Optional. Specify the MAC address or hostname of the radio, or append the interface number to form the radio ID in the AA-BB-CC-DD-EE-FF:RX or HOSTNAME:RX format.
  • <1-3> – Optional. Specify the radio interface index, if not specified as part of the radio ID.
on <DEVICE-OR-DOMAIN-NAME>Optional. This is a recursive parameter, which clears wireless radio statistics on a specified device or RF Domain.
service clear wireless wlan statistics {<WLAN-NAME>} {(on <DEVICE-OR-DOMAIN-NAME>)}
clear wireless wlan statisticsClears WLAN statistics counters
<WLAN-NAME>Optional. Clears statistics counters on a specified WLAN. Specify the WLAN name.
on <DEVICE-OR-DOMAIN-NAME>Optional. This is a recursive parameter, which clears WLAN statistics on a specified device or RF Domain.
clear xpathClears XPATH related information
requestsClears pending XPATH get requests
<1-100000>
Optional. Specifies the session number (cookie from show sessions)
  • <1-100000> – Specify the session number from 1 - 100000.
Note: Omits clearing the current session‘s pending XPATH get requests.
{grid}
cli-tables-skin [ansi|hashes|minimal|none|percent|stars| thick| thin|uf-8]Selects a formatting layout or skin for CLI tabular outputs
  • ansi – Uses ANSI characters for borders
  • hashes – Uses hashes (#) for borders
  • minimal – Uses one horizontal line between title and data rows
  • none – Displays space separated items with no decoration
  • percent – Uses the percent sign (%) for borders
  • stars – Uses asterisks (*) for borders
  • thick – Uses thick lines for borders
  • thin – Uses thin lines for borders
  • utf-8 – Uses UTF-8 characters for borders
gridOptional. Uses a complete grid instead of just title lines
clusterEnables cluster protocol management
forceForces action commands on a cluster (active, configured-state, and standby)
activeChanges the cluster run status to active
configured-stateRestores a cluster to the configured state
standbyChanges the cluster run status to standby
databasePerforms database related actions
authentication create-user username <USER-NAME> password <PASSWORD>Creates users having access rights to the database. Execute this command on the database host. However, before creating users, on the database, generate the database keyfile. For more information on generating the keyfile, see database (user exec mode).
  • username <USER-NAME> – Configures database username
    • password <PASSWORD> – Configures a password for the username specified above
In the database-policy ensure that authentication is enabled and username and password is configured. The database-client-policy also should have the same username and password configured. For more information on database-policy and database-client-policy, see database-policy global config and database-client-policy global-config.
This command is supported only on the NX 95XX, NX 96XX, and VX 9000 platforms.
database authentication delete-user username <USER-NAME>Deletes the username requires to access rights the captive-portal/NSight database
  • username <USER-NAME> – Deletes the username identified by the <USER-NAME> keyword
Once deleted, the database cannot be accessed using the specified combination of username and password.
start-shellStarts the database shell
service delete-offline-aps all
delete-offline-aps allDeletes all off-line Access Points
delete-offline-apsDeletes Access Points that have been off-line for a specified number of days and time period
day <0-999>Specifies the number of days an Access Point stays off-line to be deleted
  • <0-999> – Specify the number of off-line days from 0 - 999.
time <TIME>Optional. Specifies the off-line time period. Access Points off-line for this period of time are deleted.
  • <TIME> – Specify the time in HH:MM:SS format.
service eguest remove-data [deleted-devices|offline-for days <0-999> {time <HH:MM:SS>}]
service eguetsEnables ExtremeGuest server data maintenance
remove-dataRemoves offline and/or deleted devices from the ExtremeGuest server database
Note: When enabled, the device configuration and database collection is removed permanently.
Note: If a controller is removed, then its adopted APs are also removed,
deleted-devicesRemoves deleted devices
offline-for days <0-999> {time <HH:MM:SS>}Removes offline devices from the ExtremeGuest server database. Offline devices are devices that have not been reporting to the ExtremeGuest server for a specified number of days. Use this option to configure that threshold value. Devices that have not reported to the ExtremeGuest server for the number of days specified here are considered to be offline and removed.
  • days <0-999> – Specify the threshold, in days, from 0 - 999.
    • time <HH:MM:SS> – Option. In addition to the number of days, you can also specify the time in hours, minutes, and seconds. If specified, a device is removed if it has not reported to the server for the specified number of days and time.
eguestEnables ExtremeGuest server data maintenance
restore factory-defaultReinitializes the ExtremeGuest server to factory-default settings. Use this option to stop the ExtremeGuest server and database.
Note: Extreme caution is recommended, as this command deletes data related to ExtremeGuest server and database. Debug log files are also deleted.
force-send-configResends configuration to device(s)
on <DEVICE-OR-DOMAIN-NAME>Optional. Resends configuration to a specified device or all devices in a specified RF Domain
  • <DEVICE-OR-DOMAIN-NAME> – Optional. Specify the name of the AP, wireless controller, service platform, or RF Domain.
force-update-vm-statsForcefully pushes VM statistics on to the NOC
on <DEVICE-NAME>Optional. Executes the command on a specified device
  • <DEVICE-NAME> – Specify the name of the device.
service guest-registration backup [delete|restore]Deletes or restores all guest registration backup snapshots based on the parameter passed
  • delete – Deletes all guest registration backup snapshots
  • restores – Restores all guest registration backup snapshots
Note: To view the status of the restore process, use the service > show > guest-registration > restore-status command.
offline-for days <1-999>|wlan <WLAN-NAME>|otp-incomplete-for days <1-999>|
social [facebook|google]]
service guest-registration deleteDeletes a specified user or all user records from the guest-registration database
To delete a specific user, use one of the following options as an identification parameter: email, group, mac, mobile number, name, offline-for, wlan, otp-incomplete-for, or social.
[all|email <EMAIL-ADD>|group <RAD-GROUP-NAME>| mac <MAC>|mobile <MOBILE-NUMBER>| name <CLIENT-FULL-NAME>]|non-social| offline-for days <1-999>|wlan <WLAN-NAME>|otp-incomplete-for days <1-999>|social [facebook|google]Following are the user filtering options: The user identified by one of the following parameters is deleted from the guest-registration database.
  • email <EMAIL-ADD> – Identifies user by the e-mail address
    • <EMAIL-ADD> – Provide the user‘s e-mail address.
  • mac <MAC> – Identifies user by the MAC address
    • <MAC> – Provide the user‘s MAC address.
  • group <RAD-GROUP-NAME> – Identifies users by their RADIUS group association
    • <RAD-GROUP-NAME> – Specify the RADIUS group name.
  • mobile <MOBILE-NUMBER> – Identifies user by the registered mobile number
    • <MOBILE-NUMBER> – Provide the user‘s mobile number.
  • name <CLIENT-FULL-NAME> – Identifies user by the registered full name
    • <CLIENT-FULL-NAME> – Provide the user‘s full name.
  • non-social – Identifies users that have not registered through social authentication
  • offline-for days <1-999> – Filters users who have not accessed the network for a specified number of days
    • days <1-999> – Specify the number of days from 1 - 999.
  • wlan <WLAN-NAME> – Identifies users accessing a specified WLAN
    • <WLAN-NAME> – Specify the WLAN name.
  • otp-incomplete-for days <1-999> – Identifies records of users that have not used their OTP to complete registration within a specified number of days
  • social [facebook|google] – Identifies users using either Facebook or Google credentials to access the network
    • facebook – Identifies users using Facebook authentication
    • google – Identifies users using Google authentication
service guest-registration export format [csv|json] <DEST-URL> {(rfdomain <DOMAIN-NAME>| time [1-Day|1-Month|1-Week|2-Hours|30-Mins|5-Hours|all]|wlan <WLAN-NAME>)}
service guest-registration exportExports guest registration user data files in the Comma-Separated Values (CSV) or JSON (JavaScript Object Notation) format
Use the ‘rfdomain‘, ‘wlan‘, and ‘time‘ options to filter users for a specified RF Domain, WLAN, and/or time period. These are recursive parameters and you can apply all or any of these three filters.
format [csv|json]Specifies the file format. The options are:
  • csv – Exports user data files in the CSV format
  • json – Exports user data files in the JSON format
<DEST-URL>Configures the destination URL. The files are exported to the specified location. Both IPv4 and IPv6 address formats are supported.
  • IPv4 URLs:
    tftp://<hostname|IP>[:port]/path/file
    ftp://<user>:<passwd>@<hostname|IP>[:port]/path/file
    sftp://<user>:<passwd>@<hostname|IP>[:port]>/path/file
  • IPv6 URLs:
    tftp://<hostname|[IPv6]>[:port]/path/file
    ftp://<user>:<passwd>@<hostname|[IPv6]>[:port]/path/file
    sftp://<user>:<passwd>@<hostname|[IPv6]>[:port]>/path/file
rfdomain <DOMAIN-NAME>Optional. Filters user data based on RF Domain name. Only the filtered data are exported.
wlan <WLAN-NAME>Optional. Filters user data based on WLAN name. Only the filtered data are exported.
time [1-Day|1-Month| 1-Week|2-Hours| 30-Mins|5-Hours|all]Optional. Filters user data for a specified time period. Only the filtered data are exported.
  • 1-Day – Filters and exports previous day‘s data
  • 1-Month – Filters and exports previous month‘s data
  • 1-Week – Filters and exports previous week‘s data
  • 2-Hours – Filters and exports last 2 hours data
  • 30-Mins – Filters and exports last 30 minutes data
  • 5-Hours – Filters and exports last 5 hours data
  • all – Exports the entire database
service guest-registration import format json <SOURCE-URL>
service guest-registration importImports user data from a specified location
format jsonSpecifies the file format
  • json – Imports user data files in the JSON format
<SOURCE-URL>Configures the Source URL. The files are imported from the specified location. Both IPv4 and IPv6 address formats are supported.
  • IPv4 URLs:
  • IPv6 URLs:
load-balancingEnables wireless load balancing by clearing client capability records
clear-client-capability [<MAC>|all]Clears a specified client or all client capability records
  • <MAC> – Clears capability records of a specified client. Specify the client's MAC address in the AA-BB-CC-DD-EE-FF format.
  • all – Clears the capability records of all clients
on <DEVICE-NAME>Optional. Clears client capability records on a specified device
load-ssh-authorized-keysLoads SSH public (client) key on a device
<PUBLIC-KEY>Enter the public key. The public key should be in the OpenSSH rsa/dsa format.
on <DEVICE-NAME>Optional. Loads the specified public key on a specified device
locatorEnables LEDs
<1-60>Sets LED flashing time from 1 - 60 seconds.
on <DEVICE-NAME>The following keyword is recursive and common to the <1-60> parameter:
  • on <DEVICE-NAME> – Optional. Enables LEDs on a specified device
    • <DEVICE-NAME> – Specify name of the AP, wireless controller, or service platform.
nsight clear-offline [all|offline-for days <0-999> {time <TIME>}]Clears NSight data received from offline controllers, based on the parameters passed. Select one of the following options:
  • all – Clears NSight data received from all offline controllers
  • offline-for days <0-999> time <TIME> – Clears NSight data received from controllers that have been offline for a specified time period
    • days <0-999> – Specify the number of days controllers have been offline. Select “0” to identify controllers offline less than 24 hours.
    • time <TIME> – Optional. Specifies the total time for which controllers have been offline. Specify the time in HH:MM:SS format.
Note: This command is applicable only to the NX 95XX, NX 96XX, and VX 9000 platforms.
radio <1-3>Configures radio parameters
  • <1-3> – Specify the radio index from 1 - 3.
adaptivitySimulates the presence of interference on the current channel
service radio <1-3> channel-switch <36-196> [160|20|40|80|80-80]
channel-switch <36-196> [160|20|40|80| 80-80]Enables channel switching
  • <36-196> – Specifies the channel to switch to from 36 - 196.
    • 160|20|40|80|80-80] – Specifies the bandwidth for the above specified channel. Select the appropriate option.
service radio <1-3> dfs simulate-radar [extension|primary]
dfsEnables Dynamic Frequency Selection (DFS )
simulate-radar [extension|primary]Simulates the presence of a radar on a channel. Select the channel type from the following options:
  • extension – Simulates a radar on the radio's current extension channel
  • primary – Simulates a radar on the radio's current primary channel
radius testTests RADIUS server's account. This command sends an access-request packet to the RADIUS server. Use this command to confirm time and data/bandwidth parameters for valid wireless clients.
  • test – Tests the RADIUS server's account with user provided parameters
[<IP>|<HOSTNAME>]Sets the RADIUS server's IP address or hostname
  • <IP> – Specifies the RADIUS server's IP address
  • <HOSTNAME> – Specifies the RADIUS server's hostname
<WORD>Specify the RADIUS server's shared secret.
<USERNAME>Specify username for authentication.
<PASSWORD>Specify the password.
wlan <WLAN-NAME> ssid <SSID>Optional. Tests the RADIUS server on the local WLAN. Specify the local WLAN name.
  • ssid <SSID> – Specify the WLAN SSID.
on <DEVICE-NAME>Optional. This is a recursive parameter also applicable to the WLAN parameter. Performs tests on a specified device
service radius test [<IP>|<HOSTNAME>] <PORT> <1024-65535> <WORD> <USERNAME>
<PASSWORD> {wlan <WLAN-NAME> ssid <SSID>} {(on <DEVICE-NAME>)}
radius testTests a RADIUS server's account. This command sends an access-request packet to the RADIUS server. Use this command to confirm time and data/bandwidth parameters for valid wireless clients.
[<IP>|<HOSTNAME>]Sets the IP address or hostname of the RADIUS server
  • <IP> – Specify the RADIUS server's IP address.
  • <HOSTNAME> – Specify the RADIUS server's hostname.
<PORT> <1024-65535>Specify the RADIUS server port from 1024 - 65535. The default port is 1812.
  • ssid <SSID> – Specify WLAN SSID.
setSets the validation mode for running configuration validation
validation-mode [full|partial]Sets the validation mode
  • full – Performs a full configuration validation
  • partial – Performs a partial configuration validation
on <DEVICE-NAME>Optional. Performs full or partial configuration validation on a specified device
service show block-adopter-conflict-update
showDisplays running system statistics based on the parameters passed
block-adopter-config-updateDisplays NOC configuration blocking status
captive-portalDisplays captive portal information
log-internalDisplays recent captive portal debug logs (information and above severity level)
serversDisplays server information for active captive portals
user-cacheDisplays cached user details for a captive portal
on <DEVICE-NAME>Optional. Displays server information or cached user details on a specified device
service show [cli|client-identity-defaults|configuration-revision|mac-user-import-status|
mac-vendor <OUI/MAC>|noc diag|snmp session|xpath-history]
cliDisplays CLI tree of the current mode
client-identity-defaultsDisplays default client-identities and their configuration
configuration-revisionDisplays current configuration revision number
mac-user-import-statusDisplays status of file import initiated by a MAC-user
mac-vendor <OUI/MAC>Displays vendor name for a specified MAC address or Organizationally Unique Identifier (OUI) part of the MAC address
  • <OUI/MAC> – Specify the MAC address or its OUI. The first six digits of the MAC address is the OUI. Use the AABBCC or AA-BB-CC format to provide the OUI.
noc diagDisplays NOC diagnostic details
snmp sessionDisplays SNMP session details
xpath-historyDisplays XPath history
startup-log|ssh-authorized-keys|sysinfo|top|upgrade-history|watchdog] {on <DEVICE-NAME>}
command-historyDisplays command history (lists all commands executed)
crash-infoDisplays information about core, panic, and AP dump files
infoDisplays snapshot of available support information
memDisplays a system's current memory usage (displays the total memory and available memory)
processDisplays active system process information (displays all processes currently running on the system)
reboot-historyDisplays the device's reboot history
startup-logDisplays the device's startup log
sysinfoDisplays system's memory usage information
topDisplays system resource information
upgrade-historyDisplays the device's upgrade history (displays details, such as date, time, and status of the upgrade, old version, new version, etc.)
watchdogDisplays the device's watchdog status
on <DEVICE-NAME>The following keywords are common to all of the above:
  • on <DEVICE-NAME> – Optional. Displays information for a specified device. If no device is specified, the system displays information for logged device(s)
show ip-access-listDisplays status of IP ACL to WLAN mappings on a specified device or all devices within a specified RF Domain. This command also displays if IP ACLs are properly applied in the dataplane.
wlan <WLAN-NAME>Specifies the WLAN, for which the IP ACL to WLAN mapping status is required
status detailDisplays only failed IP ACL to WLAN mappings
  • details – Optional. Displays all (failed as well as successful) IP ACL to WLAN mapping status
on <DEVICE-OR-DOMAIN-NAME>Optional. Specifies the device name or the RF Domain name.
  • <DEVICE-OR-DOMAIN-NAME> – Specify the device name or the RF Domain. When specified, the system displays IP ACL to WLAN mapping status on the specified device or all devices within the specified RF Domain.
service show dhcp-lease {<INTERFACE-NAME>|on|pppoe1|vlan <1-4094>|wwan1} {(on <DEVICE-NAME>)}
dhcp-leaseDisplays DHCP lease information received from the server
<INTERFACE>Optional. Displays DHCP lease information for a specified router interface
  • <INTERFACE> – Specify the router interface name.
onOptional. Displays DHCP lease information for a specified device
pppoe1Optional. Displays DHCP lease information for a PPP over Ethernet interface
vlan <1-4094>Optional. Displays DHCP lease information for a VLAN interface
  • <1-4094> – Specify a VLAN index from 1 - 4094.
wwan1Optional. Displays DHCP lease information for a Wireless WAN interface
  • on <DEVICE-NAME> – Optional. Displays DHCP lease information for a specified device. If no device is specified, the system displays information for the logged device.
show diag [fds|pkts]Displays diagnostic statistics, such as LED status, fan speed, sensor temperature, open file descriptors, looped packets, etc.
fdsDisplays the number of file descriptors (fds) opened by key processes, such as the CFGD. When executed, the command displays only the file name and FD.
pktsDisplays details of looped packets captured by the dataplane and pushed to a separate queue. These queued packets are written to a log file (named loop_pkt_info.log) available at the /var2/log/ directory. Use the service > start-shell command and enter the path ‘cat /var2/log/‘ to view if the loop_pkt_info.log file exists. However, looped packet logging has to be enabled in the profile/device context. For more information, see diag (profile config mode).
The dataplane can log up to 16 looped packets at a time. Once the queue is full, no new loop packet is logged until the existing queue is cleared. To clear the logged looped packet queue execute the service > clear > diag > pkts command.
Following are the loop codes and the corresponding loop reasons:
  • (5) - "pkt looping in dataplane"
  • (51) - "loop in packet path"
  • (367) - "wispe encapsulation loop"
  • (432) - "mcx loop prevention"
  • (532) - "Port loop detected"
  • (536) - "packet loop detected by wireless bridge"
  • (41) - "IPv4 TTL exceeded"
  • (493) - "IPv6 TTL exceeded"
  • (540) - "mint TTL exceeded"
service show diag [led-status|psu|stats] {(on <DEVICE-NAME>)}
diagDisplays diagnostic statistics, such as LED status, fan speed, and sensor temperature
led-statusDisplays LED state variables and the current state
psuDisplays power supply information
statsDisplays fan speed and sensor temperature statistics
on <DEVICE-NAME>Optional. Displays diagnostic statistics for a specified device. If no device is specified, the system displays information for the logged device.
guest-registrationDisplays status of the guest-registration database snapshot related processes (export, import, and restore)
Note: To export, import, or restore a guest-registration database, use the service > guest-registration > [backup|export|import] command.]
export-statusDisplays the status of the latest export process initiated
import-statusDisplays the status of the latest import process initiated
export-statusDisplays the status of the latest restore process initiated
fast-switchingDisplays fast switching state (enabled or disabled)
on <DEVICE-NAME>Optional. Displays fast switching state for a specified device. If no device is specified, the system displays information for the logged device.
fibDisplays entries in the Forwarding Information Base (FIB)
fib6Displays FIB IPv6 static routing entries
The ExtremeWireless WiNG software allows the IPv6 FIB to maintain only IPv6 static and interface routes.
FIB is a collection of routing entries. A route entry consists of IPv6 network (which can also be a host) address, the prefix length for the network (for IPv6 routes this is between 0 - 128), and the next hop‘s (gateway) IPv6 address. Since a destination can be reached through multiple next hops, you can configure multiple routes to the same destination with multiple next hops.
table-id <0-255>Optional. Displays FIB information maintained by the system based on the table ID
  • <0-255> – Specify the table ID from 0 - 255.
mintDisplays MiNT protocol details
adopted-devices on <DEVICE-NAME>Displays adopted devices status in dpd2
  • on <DEVICE-NAME> – Optional. Displays MiNT protocol details for a specified device. If no device is specified, the system displays information for the logged device.
portsDisplays MiNT ports used by various services and features
pmDisplays the Process Monitor (PM) controlled process details
historyOptional. Displays process change history (the time at which the change was implemented, and the events that triggered the change)
on <DEVICE-NAME>Optional. Displays process change history for a specified device. If no device is specified, the system displays information for the logged device.
rf-domain-managerDisplays RF Domain manager information
diagDisplays RF Domain manager related diagnostics statistics
infoDisplays RF Domain manager related information
<MAC/HOSTNAME>The following keyword is common to the ‘diag‘ and ‘info‘ parameters:
Optional. Specify the MAC address or hostname of the RF Domain manager.
on <DEVICE-OR-DOMAIN-NAME>The following keyword is common to the ‘diag‘ and ‘info‘ parameters:
Optional. Displays diagnostics statistics on a specified device or domain
service show sites
sitesDisplays NOC sites related information
service show virtual-machine-history {(on <DEVICE-NAME>)}
show virtual-machine-historyDisplays virtual machine history based on the parameters passed
This command is applicable only to the NX 95XX and NX 96XX series service platforms. It is also available on the Privilege Executable Mode of these devices.
on <DEVICE-NAME>Optional. Displays virtual machine history on a specified device. If no device is specified, the system displays information for the logged device.
  • <DEVICE-NAME> – Specify the name of the service platform.
wirelessDisplays WLAN statistics (WLAN AAA policy, configuration parameters, VLAN assignment, etc.)
aaa-statsDisplays AAA policy statistics
adaptivity-statusDisplays the current list of channels (with interference levels exceeding the configured threshold resulting in adaptivity kicking in) and time when adaptivity kicked in on a device
credential-cacheDisplays clients cached credentials statistics (VLAN, keys, etc.)
dns-cacheDisplays cache of resolved names of servers related to wireless networking
radar-statusDisplays radar discovery status. This option displays following information:
  • If a radar has been discovered by the AP
  • The time of discovery
vlan-usageDisplays VLAN statistics across WLANs
  • on <DEVICE-NAME> – Optional. Displays running system statistics on a specified device. If no device is specified, the system displays information for the logged device.
wirelessDisplays WLAN statistics (WLAN AAA policy, configuration parameters, VLAN usage, etc.)
config-internalDisplays internal configuration parameters
log-internalDisplays recent internal wireless debug logs (info and above severity)
neighborsDisplays neighboring device statistics for roaming and flow migration
service show wireless [client|meshpoint neighbor] proc [info|stats] {<MAC>} {(on <DEVICE-OR-DOMAIN-NAME)}
clientDisplays WLAN client statistics
meshpoint neighborDisplays meshpoint related proc entries
procThe following keyword is common to client and meshpoint neighbor parameters:
  • proc – Displays dataplane proc entries based on the parameter selected
Note: These proc entries provide statistics on each wireless client on the WLAN.
Note: For the meshpoint parameter, it displays proc entries about neighbors.
infoThis parameter is common to client and meshpoint neighbor parameters. Displays information for a specified device (wireless client or neighbor) or RF Domain.
statsThis parameter is common to client and meshpoint neighbor parameters. Displays information for a specified device (wireless client or neighbor) or RF Domain.
<MAC>Displays information for a specified device (wireless client or neighbor) or RF Domain.
on <DEVICE-OR-DOMAIN-NAME>This parameter is common to client and meshpoint neighbor parameters. Displays information for a specified device (wireless client or neighbor) or RF Domain.
show
radio-internal [radio1|radio2]Displays radio internal debug logs. Select the radio from the following options:
  • radio1 – Selects radio 1
  • radio2 – Selects radio 2.
<LINE>Specify the radio internal debug command to enable.
status-codes]
referenceDisplays look up reference information related to standards, protocols, etc.
channelsDisplays 802.11 channels information
frameDisplays 802.11 frame structure
handshakeDisplays a flow diagram of 802.11 handshakes
mcs-ratesDisplays MCS rate information
reason-codesDisplays 802.11 reason codes (for deauthentication, disassociation, etc.)
status-codesDisplays 802.11 status codes (for association response)
service show wireless stats-client diag {<MAC/HOSTNAME>} {(on <DEVICE-OR-DOMAIN-NAME)}
wirelessDisplays WLAN statistics (WLAN AAA policy, configuration parameters, VLAN usage etc.)
stats-clientDisplays managed AP statistics
<MAC/HOSTNAME>Optional. Specify the MAC address or hostname of the AP.
on <DEVICE-OR-DOMAIN-NAME>Optional. Displays statistics on a specified AP, or all APs on a specified domain.
smart-rfEnables Smart RF management
clear-configClears WLAN Smart RF configuration on a specified device or on all devices
<MAC>Optional. Clears WLAN Smart RF configuration on a device identified by its MAC address. Specify the device's MAC address in the AA-BB-CC-DD-EE-FF format.
<DEVICE-NAME>Optional. Clears WLAN Smart RF configuration on a device identified by its hostname. Specify the device's hostname.
on <DOMAIN-NAME>Optional. Clears WLAN Smart RF configuration on all devices in a specified RF Domain
service smart-rf [clear-history|clear-interfering-aps|save-config] {on <DOMAIN-NAME>}
clear-historyClears WLAN Smart RF history on all devices
clear-interfering-apsClears Smart-RF interfering APs
save-configSaves the Smart RF configuration on all devices, and also saves the history on the RF Domain Manager
service snmp sysoid wing5Configures a new sysObjectID (sysoid), in the MIB, for devices running ExtremeWireless WiNG 5.X devices
When configured, the SNMP manager returns sysoid for ExtremeWireless WiNG 5.X OS. Hardware running the ExtremeWireless WiNG 4.X and ExtremeWireless WiNG 5.X images have different sysoids. For example, the sysoid for a RFS 4000 using the ExtremeWireless WiNG 4.X image differs from another RFS 4000 running the ExtremeWireless WiNG 5.X image.
This command is applicable only to RFS 4000 platform, since it has the same sysoid supported in ExtremeWireless WiNG 4.X and WiNG 5.X.
The ExtremeWireless WiNG 4.X sysoids are:
  • RFS 4000 – 1.3.6.1.4.1.388.18
The ExtremeWireless WiNG 5.X sysoids are:
  • RFS 4000 – 1.3.6.1.4.1.388.50.1.1.35
service ssm dump-core-snapshot
service ssm dump-core-snapshotTriggers a debug core dump of the SSM module
service syslog test {level [<0-7>|alerts|critical|debugging|emergencies| errors|informational|notifications|warnings]} {(on <DEVICE-NAME>)}
syslog testSends a test message to the syslog server to confirm server availability
Optional. Sets the logging level. In case syslog server is unreachable, an event is logged based on the logging level defined. This is an optional parameter, and the system configures default settings, if no logging severity level is specified.
  • <0-7> – Optional. Specify the logging severity level from 0-7. The various levels and their implications are as follows:
    • alerts – Optional. Immediate action needed (severity=1)
    • critical – Optional. Critical conditions (severity=2)
    • debugging – Optional. Debugging messages (severity=7)
    • emergencies – Optional. System is unusable (severity=0)
    • errors – Optional. Error conditions (severity=3)
    • informational – Optional. Informational messages (severity=6)
    • notifications – Optional. Normal but significant conditions (severity=5)
    • warnings – Optional. Warning conditions (severity=4). This is the default setting.
service ssm trace pattern <WORD> {on <DOMAIN-NAME>}
ssm traceDisplays the SSM module trace based on parameters passed
pattern <WORD>Configures the pattern to match
  • <WORD> – Specify the pattern to match.
on <DEVICE-NAME>Optional. Displays the SSM module trace on a specified device
wireless client beacon-requestsSends beacon measurement requests to a wireless client
<MAC>Specify the wireless client's MAC address.
mode [active|passive|table]Specifies the beacon measurement mode. The following modes are available:
  • Active – Requests beacon measurements in the active mode
  • Passive – Requests beacon measurements in the passive mode
  • Table – Requests beacon measurements in the table mode
ssid [<SSID>|any]Specifies if the measurements have to be made for a specified SSID or for any SSID
  • <SSID> – Requests beacon measurement for a specified SSID
  • any – Requests beacon measurement for any SSID
channel-report [<CHANNEL-LIST>| none]Configures channel report in the request. The request can include a list of channels or can apply to all channels.
  • <CHANNEL-LIST> – Request includes a list of channels. The client has to send beacon measurements only for those channels included in the request.
  • none – Request applies to all channels
on <DEVICE-NAME>Optional. Sends requests on a specified device
service wireless client quiet-element [start|stop]
wireless client trigger-bss-transitionEnables the quite-element information in beacons sent to wireless clients
startEnables the quite-element information in beacons sent to wireless clients. This is the start of the time period when wireless clients are to remain quiet.
stopDisables the quite-element information in beacons sent to wireless clients. Once disabled, this information is no longer included in beacons.
service wireless client trigger-bss-transition mac <MAC> {timeout <0-65535} {url <URL>} {on <DEVICE-OR-DOMAIN-NAME>}
wireless client trigger-bss-transitionSends a 80211v-Wireless Network Management BSS transition request to a client
<MAC>Specifies the wireless client's MAC address
timeout <0-65535>Specifies the time remaining, for this client. before BSS transition is initiated. In other words on completion of the specified time period, BSS transition is triggered.
  • <0-65535> – Specify a time from 0 -65535 seconds.
url <URL>Specifies session termination URL
on <DEVICE-OR-DOMAIN-NAME>Optional. Sends request on a specified device
  • <DEVICE-OR_DOMAIN-NAME> – Specify the name of the AP, wireless controller, service platform, or RF Domain.
service wireless client trigger-wnm mac <MAC> type [deauth-imminent|
wireless client trigger-wnmSends a WNM notification (action frame) to a wireless client
mac <MAC>Specifies the wireless client‘s MAC address
type [deauth-imminent| subscription-remediation]Configures the WNM notification type
  • deauth-imminent – Sends a de-authentication imminent frame
  • subscription-remediation – Sends a subscription remediation needed frame
uri <WORD> Optional. Specifies the unique resource identifier (URI)
wireless dump-core-snapshotTriggers a debug core dump of the wireless module
service wireless meshpoint zl <MESHPOINT-NAME> [on <DEVICE-NAME>] {<ARGS>| timeout <1-65535>}
service wireless meshpoint zlTriggers a zonal level debug of a specified meshpoint‘s modules
<MESHPOINT-NAME>Specify the meshpoint name
on <DEVICE-NAME>Triggers zonal level debug of a specified meshpoint‘s modules on a specified device
  • <DEVICE-NAME> – Specify the name of the device (AP, wireless controller, or service platform)
<ARGS>Optional. Specifies the zonal arguments. These zonal arguments represent the meshpoint modules identified by the zonal and subzonal arguments passed here. Also specify the debug level from 0 -7. Please see the Examples section, at the end of this topic, for more information.
timeout <1-65535>Optional. Specifies a timeout value from 1 - 65535 seconds. When specified, meshpoint logs are debugged for the time specified here.
wireless qos delete-tspecSends a delete TSPEC request to a wireless client
<MAC>Specify the MAC address of the wireless client.
tid <0-7>Deletes the Traffic Identifier (TID)
  • <0-7> – Select the TID from 0 - 7.
wireless traceDisplays the wireless module trace based on parameters passed
on <DEVICE-NAME>Optional. Displays the wireless module trace on a specified device
wireless unsanctioned ap air-terminateEnables unsanctioned access points termination
<MAC>Configures the unsanctioned access points‘ BSSID (MAC address)
on <DOMAIN-NAME>Optional. Specifies the RD Domain of the access point
  • <DOMAIN-NAME> – Specify the name of the RF Domain.
wireless wipsEnables management of WIPS parameters
clear-client-blacklist [all|mac <MAC>]Removes a specified client or all clients from the blacklist
  • all – Removes all clients from the blacklist
  • mac <MAC> – Removes a specified client form the blacklist
    • <MAC> – Specify the wireless client's MAC address.
service wireless wips clear-event-history {on <DEVICE-OR-DOMAIN-NAME}
clear-event-historyClears event history
on <DEVICE-OR-DOMAIN- NAME>Optional. Clears event history on a device or RF Domain
Syntax (Privilege Exec Mode)
The "service" command of the Priv Exec Mode is the same as the service command in the User Exec Mode. There a few modifications that have been documented in this section. For the syntax and parameters of the other commands refer to the Syntax (User Exec Mode) and Parameters (User Exec Mode) sections of this chapter.
service [block-adopter-config-updates|clear|cli-tables-skin|cluster|copy|
database|delete|delete-offline-aps|force-send-config|force-update-vm-stats|
guest-registration|load-balancing|locator|mint|pktcap|pm|radio|radius|
request-full-config-from-adopter|restore|set|show|signal|smart-rf|snmp|ssm|
start-shell|syslog|trace|wireless]
service clear crash-info {on <DEVICE-NAME>}
service copy [stats-report|tech-support]
service copy stats-report [global|rf-domain <DOMAIN-NAME>] (<FILE>|<URL>)
service copy tech-support [<FILE>|<URL>]
service database [authentication|compact|drop|maintenance-mode|primary-stepdown|
remove-all-files|replica-set|server|start-shell]
service database compact [all|captive-portal|nsight]
service database [maintenance-mode|primary-stepdown|remove-all-files|start-shell]
service database replica-set [add|delete]
service database replica-set add member [<IP>|<FQDN>] [arbiter|priority <0-255>]
service database replica-set delete member [<IP>|<FQDN>]
service database server [restart|start|stop]
service delete sessions <SESSION-COOKIES>
service mint [clear|debug-log|expire|flood]
service mint [clear [lsp-db|mlcp]|debug-log [flash-and-syslog|flash-only]|
expire [lsp|spf]|flood [csnp|lsp]]
service pktcap on [bridge|deny|drop|ext-vlan|interface|radio|rim|router|vpn|wireless]
service pktcap on [bridge|deny|drop|ext-vlan|rim|router|vpn|wireless]
{(acl-name <ACL>,count <1-1000000>,direction [any|inbound|outbound],filter <LINE>, hex,rate <1-100>,snap <1-2048>,tcpdump,verbose,write [file|url| tzsp [<IP/TZSP-HOSTNAME>])}
service pktcap on interface [<INTERFACE-NAME>|ge <1-4>|me1|port-channel <1-2>|
pppoe1|vlan <1-4094>|wwan1] {(acl-name <ACL>,count <1-1000000>, direction [any|inbound|outbound],filter <LINE>,hex,rate <1-100>,snap <1-2048>, tcpdump,verbose,write [file|url|tzsp [<IP/TZSP-HOSTNAME>])}
service pktcap on radio [<1-1024>|all] {(acl-name <ACL>,count <1-1000000>, direction [any|inbound|outbound],filter <LINE>,hex,promiscuous,rate <1-100>, snap <1-2048>,tcpdump,verbose,write [file|url|tzsp [<IP/TZSP-HOSTNAME>])}
service pm stop {on <DEVICE-NAME>}
service restore analytics-support [<FILE>|<URL>]
service show last-passwd
service signal [abort <PROCESS-NAME>|kill <PROCESS-NAME>]
service start-shell
service trace <PROCESS-NAME> {summary}
Parameters (Privilege Exec Mode)
service copy tech-support <FILE> <URL>
copy tech-supportCopies extensive system information used for troubleshooting
<FILE>Specify the location of the file to be copied, using the following format:
  • usbX:/path/file
<URL>Specify the location URL of the file to be copied. Both IPv4 andIPv6 address formats are supported.
  • tftp://<hostname|IPv4/IPv6>[:port]/path/file
  • ftp://<user>:<passwd>@<hostname|IPv4/IPv6>[:port]/path/file
  • sftp://<user>:<passwd>@<hostname|IPv4/IPv6>[:port]>/path/file
copy stats-reportCopies extensive statistical data useful for troubleshooting
[global|rf-domain <DOMAIN-NAME>]Identifies the RF Domain to copy statistical data
  • global – Copies extensive statistical data of all configured RF Domains
  • rf-domain <DOMAIN-NAME> – Copies extensive statistical data of a specified RF Domain. Specify the domain name.
<FILE>Specify the location to copy file using the following format:
  • usbX:/path/file
clear crash-infoClears all crash files
on <DEVICE-NAME>Optional. Clears crash files on a specified device. These crash files are core, panic, and AP dump
Note: This command is supported only on the NX 95XX, NX 96XX, and VX 9000 platforms.
compact [all| captive-portal|nsight]Compacts collections within the database. Each database (captive-portal and NSight) contains one or more collection, where each collection is a set of records. Use this command to make a single compact set of all collections within a database.
  • all – Compacts collections within all databases (captive-portal and NSight) being maintained
  • captive-portal – Compacts all collections within the captive portal database only
  • nsight – Compacts all collections within the NSight database only
maintenance-modePlaces the database server in the maintenance mode
primary-stepdownRequests the primary replica-set to step down. For more information on replica-sets and its creation, see database-policy (global config mode).
remove-all-filesRemoves all database-server related files (captive-portal and NSight). Use in a scenario where complete removal of all database related files is necessary, such as when downgrading to 5.8.1 or 5.8.0 version. Extreme caution is recommended when using this command.
replica-setAdds members to the database replica set. A replica set is a group of devices running the database instances that maintain the same data set. Replica sets provide redundancy and high availability, and are the basis for all production deployments. The replica set can contain a maximum of fifty (50) members, with each member (with the exception of the arbiter) hosting an instance of the database. For more information on creating replica sets, see database-policy (global config mode) .
add member [<IP>|<FQDN>]Adds members to the database replica set
  • <IP> – Identifies the member by its IP address. Specify the member‘s IP address.
  • <FQDN> – Identifies the member by its FQDN. Specify the member‘s FQDN address.
Note: Ensure that the identified members have the database instance running prior to being added to the replica set.
[arbiter| priority <0-255>]After identifying the new member, optionally specify if the member is the arbiter or not. If not the arbiter, specify the member‘s priority value.
  • arbiter – Identifies the new member as the arbiter. The arbiter does not maintain a data set and is added to the replica set to facilitate the election of the fall-back primary member. It provides that one extra vote required in the election of the primary member.
  • priority <0-255> – Identifies the new member as not being the arbiter and configures its priority value.
    • <0-255> – Specify the priority value from 0 - 255. Not applicable for the arbiter.
The priority value determines the member‘s position within the replica set as primary or secondary. It also helps in electing the fall-back primary member in the eventuality of the current primary member being unreachable.
All identified members should have the database instances running prior to being added to the replica set.
replica-setAllows deletion of members in a database replica set. For each database a single three-member replica-set can be created and maintained. For more information on creating replica sets, see database-policy (global config mode) .
delete member [<IP>|<FQDN>]Deletes members from an existing database replica set
server [restart|start|stop]Performs the following actions on the database server:
  • restart – Restarts the server
  • start – Starts the server
  • stop – Stops the server
delete sessions <SESSION-COOKIES>Deletes session cookies
  • <SESSION-COOKIES> – Provide a list of cookies to delete.
mintEnables MiNT protocol management (clears LSP database, enables debug logging, enables running silence etc.)
clear [lsp-db|mlcp]Clears LSP database and MiNT Link Control Protocol (MLCP) links
  • lsp-db – Clears MiNT Label Switched Path (LSP) database
  • mlcp – Clears MLCP links
debug-log [flash-and-syslog| flash-only]Enables debug message logging
  • flash-and-syslog – Logs debug messages to the flash and syslog files
  • flash-only – Logs debug messages to the flash file only
expire [lsp|spf]Forces expiration of LSP and recalculation of Shortest Path First (SPF)
  • lsp – Forces expiration of LSP
  • spf – Forces recalculation of SPF
flood [csnp|lsp]Floods control packets
  • csnp – Floods our Complete Sequence Number Packets (CSNP)
  • lsp – Floods our LSP
pmStops the PM
stopsStops the PM from monitoring all daemons
on <DEVICE-NAME>Optional. Stops the PM on a specified device
service pktcap on [bridge|deny|drop|ext-vlan|rim|router|vpn|wireless]  {(acl-name <ACL>,count <1-1000000>,direction [any|inbound|outbound],filter,hex,rate <1-100>, snap <1-2048>,tcpdump,verbose,write [file|url|tzsp <IP/TZSP-HOSTNAME>])}
pktcap onCaptures data packets crossing at a specified location
  • on – Defines the packet capture location
bridgeCaptures packets transiting through the Ethernet bridge
denyCaptures packets denied by an ACL
dropCaptures packets at the drop locations
ext-vlanCaptures packets forwarded to or from an extended VLAN
rimCaptures packets at the Radio Interface Module (RIM)
routerCaptures packets transiting through an IP router
vpnCaptures packets forwarded to or from a VPN link
wirelessCaptures packets forwarded to or from a wireless device
acl-name <ACL>Optional. Specify the ACL that matches the ACL name for the 'deny' location
count <1-1000000>Optional. Limits the captured packet count. Specify a value from 1 -1000000.
direction [any|inbound|outbound]Optional. Changes the packet direction with respect to a device. The direction can be set as any, inbound, or outbound.
filter [<LINE>|arp|capwap| cdp|dot11|dropreason| dst|ether|host|icmp| igmp|ip|ipv6|l2|l3|l4| lldp|mint|net|not|port| priority|radio|src|tcp|udp| vlan|wlan] Optional. Filters packets based on the option selected (must be used as a last option). The filter options are:
  • <LINE> – Defines user defined packet capture filter
  • arp – Matches ARP packets
  • capwap – Matches CAPWAP packets
  • cdp – Matches CDP packets
  • dot11 – Matches 802.11 packets
  • dropreason – Matches packet drop reason
  • dst – Matches IP destination
  • ether – Matches Ethernet packets
  • failed – Matches failed 802.11 transmitted frames
  • host – Matches host destination
  • icmp – Matches ICMP packets
  • icmp6 – Matches ICMPv6 frames
  • ip – Matches IPV4 packets
  • ipv6 – Matches IPV6 packets
  • l2 – Matches L2 header
  • l3 – Matches L3 header
  • l4 – Matches L4 header
  • mint – Matches MiNT packets
  • lldp – Matches LLDP packets
  • net – Matches IP in subnet
  • not – Filters out any packet that matches the filter criteria (For example, if not TCP is used, all tcp packets are filtered out)
  • port – Matches TCP or UDP port
  • priority – Matches packet priority
  • radio – Matches radio
  • rssi – Matches Received Signal Strength Indication (RSSI) of received radio signals
  • src – Matches IP source
  • stp – Matches STP packets
  • tcp – Matches TCP packets
  • tcp6 – Matches TCP over IPv6 packets
  • udp – Matches UDP packets
  • udp6 – Matches UDP over IPv6 packets
  • vlan – Matches VLAN
  • wlan – Matches WLAN
hexOptional. Provides binary output of the captured packets
rate <1-100>Optional. Specifies the packet capture rate
  • <1-100> – Specify a value from 1 - 100 seconds.
snap <1-2048>Optional. Captures the data length
  • <1-2048> – Specify a value from 1 - 2048 characters.
tcpdumpOptional. Decodes tcpdump. The tcpdump analyzes network behavior, performance, and infrastructure. It also analyzes applications that generate or receive traffic.
verboseOptional. Displays full packet body
writeCaptures packets to a specified file. Provide the file name and location in the following format:
FILE – flash:/path/file
  • flash:/path/file
  • usbX:/path/file
URL – Specify the location URL to capture file. Both IPv4 and IPv6 address formats are supported.
  • nvram:startup-config
  • tftp://<hostname|IP>[:port]/path/file
  • ftp://<user>:<passwd>@<hostname|IP>[:port]/path/file
  • sftp://<user>@<hostname|IP>[:port]>/path/file
  • tzsp – Tazman Sniffer Protocol (TZSP) host. Specify the TZSP host‘s IP address or hostname.
service pktcap on radio [<1-1024>|all] {(acl-name <ACL>,count <1-1000000>, direction [any|inbound|outbound],filter <LINE>,hex,promiscuous,rate <1-100>, snap <1-2048>,tcpdump,verbose,write [file|url|tzsp <IP/TZSP-HOSTNAME>])}
pktcap on radioCaptures data packets on a radio (802.11)
<1-1024>Captures data packets on a specified radio
  • <1-1024> – specify the radio index from 1 - 1024.
allCaptures data packets on all radios
count <1-1000000>Optional. Sets a specified number of packets to capture
  • <1-1000000> – Specify a value from 1 - 1000000.
filter <LINE>Optional. Filters packets based on the option selected (must be used as a last option)
  • <LINE> – Define a packet capture filter or select any one of the available options.
tcpdumpOptional. Decodes the TCP dump
  • flash:/path/file
  • usbX:/path/file
  • tzsp – TZSP host. Specify the TZSP host‘s IP address or hostname.
service pktcap on interface [<INTERFACE>|ge <1-4>|me|port-channel <1-2>|vlan
<1-4094>] {(acl-name <ACL>,count <1-1000000>,direction [any|inbound|outbound], filter <LINE>,hex,rate <1-100>,snap <1-2048>,tcpdump,verbose, write [file|url|tzsp <IP/TZSP-HOSTNAME>])}
pktcap onCaptures data packets at a specified interface
  • on – Specify the capture location.
interface [<INTERFACE>| ge <1-4>|me1| port-channel <1-2>| vlan <1-4094>]Captures packets at a specified interface. The options are:
  • <INTERFACE> – Specify the interface name.
  • ge <1-4> – Selects a GigabitEthernet interface index from 1 - 4
  • me1 – Selects the FastEthernet interface
  • port-channel <1-2> – Selects a port-channel interface index from 1- 2
  • vlan <1-4094> – Selects a VLAN ID from 1 - 4094
  • flash:/path/file
  • usbX:/path/file
last-passwdDisplays the last password used to enter shell
signalSends a signal to a process
  • tech-support – Copies extensive system information useful for troubleshooting
abortSends an abort signal to a process, and forces it to dump to core
  • <PROCESS-NAME> – Specify the process name.
killSends a kill signal to a process, and forces it to terminate without a core
service start-shell
start-shellProvides shell access
traceTraces a process for system calls and signals
<PROCESS-NAME>Specifies the process name
summaryOptional. Generates summary report of the specified process
Syntax (Privilege Exec Mode: NX 95XX)
Service Commands - Intro
The following service commands are specific to the NX 95XX series service platforms:
service copy analytics-support [<FILE>|<URL>]
Parameters(Privilege Exec Mode: NX 95XX)
copy analytics-supportEnables copying of analytics information to a specified. Use one of the following options to specify the file:
Note: This information is useful to troubleshoot issues by the Technical Support team.
<FILE>Specify the file name and location using one of the following formats:
  • usb1:/path/file
  • usb2:/path/file
<URL>Specify the location URL to copy file. Both IPv4 and IPv6 formats are supported.
Usage Guidelines
The NX 95XX service platforms provide granular and robust analytic reporting for a managed network. The data analyzed is collected at intervals specified by the administrator.
To enable data analytics, procure and apply a separate hot spare analytics license at the NOC. The license restricts the number of Access Point streams processed at the NOC or forwarded to partner systems for further processing. The analytics feature can be turned on at select APs by enabling them in configuration. This way the customer can enable analytics on a select set of APs and not the entire system as long as the number of APs on which it is enabled is less than or equal to the total number of AP at the NOC controller.
In an NOC managed network, the analytics engine parses and processes Smart RF events as they are received. The analytics engine parses the new channel and power information from the Smart RF event, as opposed to retrieving the event from the devices themselves. analytics licenses available.
Syntax (Global Config Mode)
service [set|show cli]
service set [command-history <10-300>|upgrade-history <10-100>|reboot-history <10-100>|
virtual-machine-history <10-200>] {on <DEVICE-NAME>}
service show cli
Parameters (Global Config Mode)
setSets the size of history files
command-history <10-300>Sets the size of the command history file
  • <10-300> – Specify a value from 10 - 300. The default is 200.
upgrade-history <10-100>Sets the size of the upgrade history file
  • <10-100> – Specify a value from 10 - 100. The default is 50.
reboot-history <10-100>Sets the size of the reboot history file
virtual-machine-history <10-200>Sets the size of the virtual-machine history file
  • <10-200> – Specify a value from 10 - 200. The default is 100.
This command is applicable only to the NX 95XX and NX 96XX series service platforms. Use the no > service > set > virtual-machine-history > {on <DEVICE-NAME>} command to revert the history file size to 100.
on <DEVICE-NAME>
Optional. Sets the size of history files on a specified device
service show cli
show cliDisplays running system configuration details
  • cli – Displays the CLI tree of the current mode
nx9500-6C8809>service show cli
Command mode:  +-do
+-help [help]
  +-search
    +-WORD [help search WORD (|detailed|only-show|skip-show|skip-no)]
      +-detailed [help search WORD (|detailed|only-show|skip-show|skip-no)]
      +-only-show [help search WORD (|detailed|only-show|skip-show|skip-no)]
      +-skip-show [help search WORD (|detailed|only-show|skip-show|skip-no)]
      +-skip-no [help search WORD (|detailed|only-show|skip-show|skip-no)]
+-show
  +-commands [show commands]
  +-global
    +-device-list [show global device-list (|(filter {|(online)|(offline)|(rf-domain (|not) RF-DOMAIN)}))]
      +-filter [show global device-list (|(filter {|(online)|(offline)|(rf-domain (|not) RF-DOMAIN)}))]
        +-online [show global device-list (|(filter {|(online)|(offline)|(rf-domain (|not) RF-DOMAIN)}))]
        +-offline [show global device-list (|(filter {|(online)|(offline)|(rf-domain (|not) RF-DOMAIN)}))]
        +-rf-domain
          +-not
            +-RF-DOMAIN [show global device-list (|(filter {|(online)|(offline)|(rf-domain (|not) RF-DOMAIN)}))]
     --More--
nx9500-6C8809>
nx9500-6C8809#service signal abort testprocess
Sending an abort signal to testprocess
nx9500-6C8809#
ap505-13403B*#service show crash-info
                   CRASH FILE                     SIZE         LAST MODIFIED
  panic_201902201741_AP505_7.1.0.0-075D.tar.gz 18727 Wed Feb 20 17:41:07 2019
ap505-13403B*#
nx9500-6C8809#service show command-history on ap8132-74B45C
Configured size of command history is 200
  Date & Time          User      Location           Command
Nov 08 10:19:11 2017   admin     127.0.0.1 16      self
Nov 08 09:19:29 2017   admin     127.0.0.1 13      revert
Nov 08 09:18:52 2017   admin     127.0.0.1 13      interface radio 1
Nov 08 09:18:44 2017   admin     127.0.0.1 13      self
Nov 08 11:34:25 2017   admin     127.0.0.1 9      revert
Nov 08 11:34:06 2017   admin     127.0.0.1 9      self
Oct 06 07:15:18 2017   admin     Console 6      self
Oct 06 07:15:01 2017   admin     Console 6      self
Oct 06 07:14:17 2017   admin     Console 6      wr mem
Oct 06 07:14:12 2017   admin     Console 6      change-passwd
Oct 06 12:39:07 2017   admin     Console 6      reload force
Oct 06 12:38:49 2017   admin     Console 6      self
Oct 06 12:20:39 2017   admin     Console 6      write memory
Oct 06 12:20:33 2017   admin     Console 6      commit
--More--
nx9500-6C8809#
nx9500-6C8809#service show diag stats
fan 1 (System Fan 1) current speed: 2765 min_speed: 693 hysteresis: 250
fan 2 (System Fan 2) current speed: 3010 min_speed: 665 hysteresis: 250
fan 3 (System Fan 3) current speed: 2695 min_speed: 665 hysteresis: 250
fan 4 (System Fan 4) current speed: 3045 min_speed: 665 hysteresis: 250
fan 5 (System Fan 5) current speed: 6188 min_speed: 665 hysteresis: 250
fan 6 (System Fan 6) current speed: 5564 min_speed: 665 hysteresis: 250
Sensor 1 (Baseboard) Temperature 30.0 C
Sensor 2 (Front Panel) Temperature 20.0 C
Sensor 3 (PS1) Temperature 25.0 C
Sensor 4 (PS2) Temperature 27.0 C
Sensor 5 (HSBP) Temperature 21.0 C
nx9500-6C8809#
nx9500-6C8809#service show upgrade-history
Configured size of upgrade history is 50
  Date & Time            Old Version     New Version     Status
Feb 02 08:34:30 2018 5.9.2.0-007D 5.9.2.0-008D Successful
Jan 29 09:40:12 2018 5.9.2.0-005D 5.9.2.0-007D Successful
Jan 03 10:32:08 2018 5.9.1.0-029R 5.9.2.0-005D Successful
Sep 22 10:31:03 2017 5.9.1.0-026B 5.9.1.0-029R Successful
Sep 15 12:07:21 2017 5.9.1.0-025B 5.9.1.0-026B Successful
Sep 12 15:24:16 2017 5.9.1.0-025D 5.9.1.0-025B Successful
Sep 11 12:09:07 2017 5.9.1.0-024D 5.9.1.0-025D Successful
Sep 04 13:59:54 2017 5.9.1.0-023D 5.9.1.0-024D Successful
Sep 01 10:06:22 2017 5.9.1.0-022D 5.9.1.0-023D Successful
--More--
nx9500-6C8809#
nx9500-6C8809#service show wireless reference reason-codes
 CODE  DESCRIPTION
  0    Success
  1    Unspecified Reason
  2    Previous authentication no longer valid
  3    Deauth because sending STA is leaving IBSS or ESS
  4    Disassoc due to inactivity
  5    Disassoc because AP is unable to handle all currently assoc STA
  6    Class 2 frame received from non-authenticated STA
  7    Class 3 frame received from nonassociated STA
  8    Disassoc because STA is leaving BSS
  9    STA requesting association is not authentication with corresponding STA
 10    Disassoc because info in the power capability elem is unacceptable
 11    Disassoc because info in the supp channels elem is unacceptable
 12    Reserved
--More--
nx9500-6C8809#
 CODE  DESCRIPTION
  0    Success
--More--
nx9500-6C8809#
nx9500-6C8809>service show wireless config-internal
! Startup-Config-Playback Completed: Yes
no debug wireless
country-code in
nx9500-6C8809>
nx9500-6C8809#service show wireless log-internal
08:51:49.417: wlan:Starting credcache checkup/sync (credcache.c:1539)
08:31:47.416: wlan:Starting credcache checkup/sync (credcache.c:1539)
08:11:42.415: wlan:Starting credcache checkup/sync (credcache.c:1539)
07:51:42.412: wlan:Starting credcache checkup/sync (credcache.c:1539)
07:31:42.412: wlan:Starting credcache checkup/sync (credcache.c:1539)
07:11:37.409: wlan:Starting credcache checkup/sync (credcache.c:1539)
06:51:36.408: wlan:Starting credcache checkup/sync (credcache.c:1539)
06:31:27.408: wlan:Starting credcache checkup/sync (credcache.c:1539)
06:11:24.408: wlan:Starting credcache checkup/sync (credcache.c:1539)
05:51:21.407: wlan:Starting credcache checkup/sync (credcache.c:1539)
05:31:18.406: wlan:Starting credcache checkup/sync (credcache.c:1539)
05:11:11.405: wlan:Starting credcache checkup/sync (credcache.c:1539)
--More--
nx9500-6C8809#
nx9500-6C8809#service show xpath-history
          DATE&TIME             USER                                    XPATH                                   DURATION(MS)
  Mon Feb  5 14:20:38 2018    system    wing-stats/device/B4-C7-99-6C-88-09/upgrade-history                     10
  Mon Feb  5 14:16:37 2018    system    wing-stats/device/B4-C7-99-6C-88-09/service-info                        28
  Mon Feb  5 14:15:11 2018    system    wing-stats/device/B4-C7-99-6C-88-09/diag/temp                           449
  Mon Feb  5 14:15:09 2018    system    wing-stats/device/B4-C7-99-6C-88-09/diag/fan                            1748
  Mon Feb  5 14:12:49 2018    system    wing-stats/device/B4-C7-99-74-B4-5C/command-history                     49
  Fri Feb  2 16:10:58 2018    system    wing-stats/device/B4-C7-99-6C-88-09/content-filter/web_filter_policy    0
--More--
nx9500-6C8809#
The following example shows the service > show > virtual-machine-history output on a NX 9500 service platform:
nx9500-6C874D>service show virtual-machine-history
Configured size of virtual machine history is 100
  Date & Time        Virtual Machine  Event
Jan 16 05:39:46 2017  Domain-0         autostart
Jan 10 03:47:09 2017  Domain-0         autostart
Jan 02 05:53:48 2017  Domain-0         autostart
Dec 27 10:52:59 2016  Domain-0         autostart
Oct 14 05:56:14 2016  Domain-0         autostart
Oct 14 03:01:48 2016  Domain-0         autostart
Oct 12 04:11:52 2016  Domain-0         autostart
Sep 30 04:41:08 2016  Domain-0         autostart
--More--
nx9500-6C874D>
Examples for the service > wireless > meshpoint command.
The following example displays meshpoint modules:
ROOT1-ap81xx-71174C#service wireless meshpoint zl mesh_root on ROOT1-ap81xx-71174C
       | SUBZONE
       | 0    1    2    3    4    5    6    7
  ZONE |
       | GEN  TX   RX   BEA  TXF
 2-LLC | 0    0    0    0    0
       | GEN  TX   RX   NBR  LQM  LSA
 3-ND  | 0    0    0    0    0    0
       | GEN
 4-ORL | 0
       | GEN  TX   RX   HEL  PRO
 5-LQ  | 0    0    0    0    0
       | GEN
 6-PS  | 0
       | GEN  ROOT NBR  REC
 7-RS  | 0    0    0    0
       | GEN
 8-IA  | 0
       | GEN  SET  GET
11-MGT | 0    0    0
       | GEN  RX   TX   R0   LMST LSUP LKEY KEY
13-LSA | 0    0    0    0    0    0    0    0
       | GEN  SCAN TRIG
14-ACS | 0    0    0
       | GEN
15-EAP | 0
       | GEN
16-L2P | 0
In the preceding example,
  • The meshpoint name is mesh_root
  • The device on which the command is executed is ROOT1-ap81xx-71174C
  • The vertical ZONE column represents meshpoint modules. For example, 3-ND presents the Neighbor Discovery module.
  • The SUBZONE 0 to 7 represents the available processes for each of the zonal modules.
  • Debugging is disabled for all modules for the mesh-root meshpoint. A value of 0 (Zero) represents debugging disabled.
To enable meshpoint module debugging, specify the module number and the process number separated by a period (.). And then specify the debugging level from 0 - 7.
ROOT1-ap81xx-71174C#service wireless meshpoint zl mesh_root on ROOT1-ap81xx-71174C 3.2 7
In the preceding command,
  • The meshpoint module number provided is 3 (ND)
  • The process number provided is 2 (RX - Received signals from neighbors)
  • The debugging level provided is 7 (highest level - warning)
       | SUBZONE
       | 0    1    2    3    4    5    6    7
  ZONE |
       | GEN  TX   RX   BEA  TXF
 2-LLC | 0    0    0    0    0
 3-ND  | 0    0    7(D) 0    0    0
       | GEN
 4-ORL | 0
       | GEN  TX   RX   HEL  PRO
 5-LQ  | 0    0    0    0    0
       | GEN
 6-PS  | 0
       | GEN  ROOT NBR  REC
 7-RS  | 0    0    0    0
       | GEN
 8-IA  | 0
       | GEN  SET  GET
11-MGT | 0    0    0
       | GEN  SCAN TRIG
14-ACS | 0    0    0
       | GEN
15-EAP | 0
       | GEN
16-L2P | 0
In the preceding example, level 7 debugging has been enabled only for the ND module‘s received signals. Note that debugging for all other modules and processes are still disabled.
To disable debugging for all modules, specify 0 (zero) in the command. For example:
ROOT1-ap81xx-71174C#service wireless meshpoint zl mesh_root on ROOT1-ap81xx-71174C 0
To enable debugging for all modules, specify the debugging level number. For example:
ROOT1-ap81xx-71174C#service wireless meshpoint zl mesh_root on ROOT1-ap81xx-71174C 5
       | SUBZONE
       | 0    1    2    3    4    5    6    7
  ZONE |
       | GEN  TX   RX   BEA  TXF
 2-LLC | 5(N) 5(N) 5(N) 5(N) 5(N)
 3-ND  | 5(N) 5(N) 5(N) 5(N) 5(N) 5(N)
       | GEN
 4-ORL | 5(N)
       | GEN  TX   RX   HEL  PRO
 5-LQ  | 5(N) 5(N) 5(N) 5(N) 5(N)
       | GEN
 6-PS  | 5(N)
       | GEN  ROOT NBR  REC
 7-RS  | 5(N) 5(N) 5(N) 5(N)
       | GEN
 8-IA  | 5(N)
       | GEN  SET  GET
11-MGT | 5(N) 5(N) 5(N)
13-LSA | 5(N) 5(N) 5(N) 5(N) 5(N) 5(N) 5(N) 5(N)
       | GEN  SCAN TRIG
14-ACS | 5(N) 5(N) 5(N)
       | GEN
15-EAP | 5(N)
       | GEN
16-L2P | 5(N)
rfs4000-1BE644#service show ssh-authorized-keys
'extreme@extreme-quadcore'
rfs4000-1BE644#
rfs4000-1BE644#service load-ssh-autorized-keys "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDPERY9aTibRYlFMnERTYP2iyylJ00YElxjUElY7Zm9Ky2yeSmg15UKerJ+IP161Gdm0AoEfXyeheRntK+Z6NWHa341RWJ0UrQMcp7hSEE5jbDpLKJOuEoW22Ag45BZzMV7EnM7lHowboNsQhSzX5uBBlVViWlBxBqDroX4BcuB/CFugezHTt95UQ2ZRUfHvePS6jQdOArf1alwk0Slcsz4HNSl5KDutJ4VY+6vRvlf5Gy/3GNehMwNsmsRKK4UVKV5RpuuKIjkbZE+goPFAKYVPNmZngjaOyDfvNGE7JIwmYlti/AId6tv2zAbM4qSomWAgUOO0hkXS9m4m74FnHPr extreme@extreme-quadcore"
Successfully added the ssh key
rfs4000-1BE644#
rfs4000-1BE644#no service load-ssh-autorized-keys rfs4000-1BE644
Successfully removed the ssh key
rfs4000-1BE644#
nx9500-6C8809#service show diag fds
Process  open fds
cfgd      86
nx9500-6C8809#
nx9500-6C8809#service show diag pkts
Date: 11-4-2016, Time: 8:41:08.501033, Len: 64, 802.3, Proto: 0x8783, Vlan: 1, Priority: 0, Ingress: ge1, vlan1
Loop reason: Unknown(540)
TRUNCATED BB-7C-4D-80-C2-AC > 10-01-00-D2-68-99 at 64 bytes
Date: 11-4-2016, Time: 8:41:08.707631, Len: 64, 802.3, Proto: 0x8783, Vlan: 1, Priority: 0, Ingress: ge1, vlan1
Date: 11-4-2016, Time: 8:41:08.830963, Len: 64, 802.3, Proto: 0x8783, Vlan: 1, Priority: 0, Ingress: ge1, vlan1
TRUNCATED BB-7C-4D-83-30-A4 > 10-01-00-42-68-99 at 64 bytes
--More--
nx9500-6C8809#
nx9500-6C8809#service clear diag pkts
            nx9500-6C8809#
nx9500-6C8809#service show diag psu
PSU1 (upper):
 status unplugged
PSU2 (lower):
 status normal
nx9500-6C8809#
The following examples show the purging of users from the guest-registration database:
nx7500-112233#service guest-registration delete ?
  all                 Delete all users
  email               Email address
  group               Group
  mac                 MAC address
  mobile              Mobile phone number
  name                Full name
  offline-for         Specify minimum amount of time offline
  otp-incomplete-for  Specify minimum amount of time registration with
                      one-time-passcode incomplete
  social              Social site used to log in
  wlan                Wireless LAN
nx7500-112233#
Purges users belonging to a specified RADIUS group.
nx7500-112233#service guest-registration delete group mac_reg_gr1
delete user status: delete users matching a group will take time, please wait
nx7500-112233#
Purges users using social-site (Facebook or Google) credentials to login.
nx7500-112233#service guest-registration delete social facebook
delete user status: delete users matching a social category will take time, please wait
nx7500-112233#
Purges users inactive for a specified time period.
nx7500-112233#service guest-registration delete offline-for days 5
delete user status: Deleting users offline for minimum 5 days. This will take time, please wait
nx7500-112233#
Purges users who have failed to complete registration using the OTP within a specified time period.
nx7500-112233#service guest-registration delete otp-incomplete-for days 5
delete user status: Deleting registration with one-time-passcode incomplete for minimum 5 days. This will take time, please wait
nx7500-112233#
The following example displays IP ACLs to WLAN mapping summary on the ‘TechPubs‘ RF Domain:
nx9500-6C8809#service show ip-access-list wlan TechPubs status
Reporting Device: ap7532-80C2AC - success
Reporting Device: ap7562-84A224 - success
Reporting Device: nx9500-6C8809 - success
Reporting Device: ap8163-74B45C - success
Total reporting devices: 5
nx9500-6C8809#
Consider an RF Domain (name guest-domain) with 3 APs adopted to a controller. The CLI output for the service > show > ip-access-list command in this set up varies for different scenarios, as shown in the following examples:
  • Scenario 1: Executing the command on a device (access point).
    AP01#service show ip-access-list wlan status
    Reporting Device: AP01 - fail
    WLAN: XPO-Guest-PSK
      use ip-access-list in guest_access_inbound : fail
    Total reporting devices: 1
    AP01#
    AP01#service show ip-access-list wlan status detail
    WLAN: XPO-Guest-PSK
      use ip-access-list out BC-MC-CONTROL : success
    WLAN: PartnerNet
      use ip-access-list in default : success
      use ip-access-list out default : success
    AP01#
  • Scenario 2: IP ACL to WLAN mapping is successful for all APs in a specified RF Domain.
    SW01#service show ip-access-list wlan status on guest-domain
    Reporting Device: AP01 - success
    Reporting Device: AP02 - success
    Reporting Device: AP03 - success
    Total reporting devices: 3
    SW01#
  • Scenario 3: IP ACL has failed in dataplane due to unknown reasons.
    WLAN: XPO-Guest-PSK
    SW01#
    SW01#service show ip-access-list wlan status detail on guest-domain
    WLAN: XPO-Guest-PSK
    WLAN: PartnerNet
      use ip-access-list in guest_access_inbound : success
    WLAN: PartnerNet
    WLAN: PartnerNet
    SW01#
  • Scenario 4: AP in RF Domain is unreachable or does not support this functionality.
    Reporting Device: AP01 - unreachable
    SW01#
    Timed out waiting for remote device: xpath=wing-stats/device/00-23-68-0B-86-38/firewall/
    ip_acl_intf_status/wlan[mac='*']
    WLAN: PartnerNet
    WLAN: PartnerNet
    SW01#
