server-host
Configures the ExtremeLocation server‘s hostname. When configured, the ExtremeWireless WiNG controller stages the Tenant‘s site hierarchy information to the specified server.
Syntax
server-host 1 ip <HOSTNAME> {port <1-65535>}
Parameters
server-host 1 ip <HOSTNAME>Identifies the ExtremeLocation server by its hostname
  • <HOSTNAME> – Enter ExtremeLocation server‘s hostname.
    Note: Enter the server‘s hostname and not the IP address, as the IP address is likely to change periodically in order to balance load across multiple Location server instances.
{port <1-65535>}optional. Configures the port on which the ExtremeLocation server is reachable
  • <1-63335> – Selects a port from 1 - 65535 for the ExtremeLocation server.
    Note: By default the ExtremeLocation server is reachable on port 443.
nx9500-6C8809(config-location-policy-ELocPolicy)#server-host 1 ip xyz.com
nx9500-6C8809(config-location-policy-ELocPolicy)#show context
location-policy ELocPolicy
 enable
 server-host 1 ip xyz.com port 443
 location-key dGVzdEAxMjM0NQo
Related Commands
no (location-policy-config-commands)Removes ExtremeLocation server's hostname from the policy
