AP510i is a next generation, enterprise-class 802.11ax access point. The “i” in AP510i indicates that it comes with internal antennas. The AP features a dual-band radio, a band locked radio, and comes with eight (8) WiFi internal antennas and one BLE antenna.
Radios: 2 radios; 1 IoT radio (2.4 GHz).
Console Port: RJ45.
Two Ethernet Ports:
GE1 - 10/100/1000/2500/5000 Mbps auto-negotiation Ethernet port, RJ45, with PoE In
GE2 - 10/100/1000 Mbps auto-negotiation Ethernet port, RJ45, with PoE In
LEDs: 6 – All LEDs will be on during reset
One Reset button
Power: PoE 802.3at; 12VDC external power in connector
