window-size (iot-device-type-imagotag-policy)
Configures the transmission window size for messages exchanged between ESL communicator and tags
- Access Points — AP-8432
- Wireless Controllers — RFS 4000
- Service Platforms — NX 5500, NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
window-size <1-14>
Parameters
window-size <1-14>
| window-size <1-14> | Configures the window size- <1-14> – Specify a value from 1 - 14 bytes. The default value is 14 bytes.
Note: SES-Imagotags recommends NOT to change the default setting.
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#window-size 12
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
iot-device-type-imagotag-policy ImagoTagPolicy
enable
output-power Level-B
window-size 12
payload-size 25
port 200
ssl-enable
fcc-enable
channel 9
