smart-rf
interface-config-radio-instance
Overrides Smart RF channel width setting on this radio. When configured, the radio overrides the Smart RF selected channel setting and operates in the channel configured using this command.
Syntax
smart-rf preferred-channel-width [20MHz|40MHz|80MHz]
Parameters
smart-rf preferred-channel-width [20MHz| 40MHz|80MHz]Configures the preferred channel width. The options are:
  • 20MHz – Sets 20 MHz as the preferred channel of operation
  • 40MHz – Sets 40MHz as the preferred channel of operation
  • 80MHz – Sets 80MHz as the preferred channel of operation (default setting)
nx9500-6C8809(config-profile-testAP510-if-radio1)#smart-rf preferred-channel-width 40MHz
nx9500-6C8809(config-profile-testAP510-if-radio1)#show context
 interface radio1
  rate-selection opportunistic
Related Commands
no (radio-interface-config-command)Enables use of Smart RF selected channel of operation
