guest-management-policy
Configures a guest management policy that redirects guest users to a registration portal upon association to a captive portal. Guest users are redirected to an internally (or) externally hosted registration page (registration.html) where previously, not-registered guest users can register. The internally hosted captive portal registration page can be customized based on business requirements.
Use the guest management policy commands to configure parameters, such as E-mail host and SMS gateway along with the credentials required for sending pass code to guest via e-mail and SMS. You can configure up to 32 different guest management policies. Each guest management policy allows you to configure the SMS gateway, SMS message body, E-mail SMTP server, E-mail subject contents, and E-mail message body. Although, at any point-in-time, multiple guest management policies may exist, only one guest management policy can be active per device.
Guest registration is supported only on the NX9500 and NX7500 series service platforms. However, the number of user identity entries supported on each varies. It is 2 million and 1 million user-identity entries for the NX9500 and NX7500 model service platforms respectively.
Supported on the following platforms:
Syntax
guest-management <POLICY-NAME>
Parameters
<POLICY-NAME>Specify the guest management policy name. If the policy does not exist, it is created.
nx9500-6C8809(config)#guest-management guest
nx9500-6C8809(config-guest-management-guest)#?
Guest Management Mode commands:
  email                  Email guest-notification configuration
  guest-database-backup  Configure guest-database-backup parameters
  guest-database-export  Configure guest-database-export parameters
  no                     Negate a command or set its defaults
  sms                    SMS guest-notification configuration
  sms-over-smtp          Sms-over-smtp configuration to email sms gateway
                         address
  clrscr                 Clears the display screen
  commit                 Commit all changes made in this session
  do                     Run commands from Exec mode
  end                    End current mode and change to EXEC mode
  exit                   End current mode and down to previous mode
  help                   Description of the interactive help system
  revert                 Revert changes
  service                Service Commands
  show                   Show running system information
  write                  Write running configuration to memory or terminal
Related Commands
noRemoves an existing guest management policy
