Specifies the EAP authentication mechanisms supported by each of the service providers associated with this passpoint policy.
eap-method <1-10> [<1-255>|fast|gtc|identity|ikev2|ms-auth|mschapv2|otp|peap|psk|rsa-public-key| sim|tls|ttls] auth-param [credential|expanded-eap|expanded-inner-eap|inner-eap|non-eap-inner| tunn-eap-credential|vendor] [cert|hw-token|nfc-secure-elem|none|sim|soft-token|username-password|usim| vendor]
eap-method <1-10> |
Selects the EAP authentication method used and assigns it an index number
A maximum of 10 (ten) authentication methods can be specified for every NAI realm. After creating the EAP authentication method, specify the associated authentication mechanisms (method types). |
<1-255> |
Identifies the EAP authentication method type from the corresponding IANA (Internet Assigned Numbers Authority number
fast |
Specifies the EAP authentication method type as FAST (Flexible Authentication via Secure Tunneling) |
gtc |
Specifies the EAP authentication method type as GTC (Generic Token Card) |
identity |
Specifies the EAP authentication method type as Identification |
ikev2 |
Specifies the EAP authentication method type as IKEv2 (Internet Key Exchange Protocol version 2) |
ms-auth |
Specifies the EAP authentication method type as MS-Auth (Microsoft Authentication) |
mschapv2 |
Specifies the EAP authentication method type as MSCHAPv2 (Microsoft Challenge Handshake Authentication Protocol Version 2) |
opt |
Specifies the EAP authentication method type as OTP (One Time Password) |
peap |
Specifies the EAP authentication method type as PEAP (Protected Extensible Authentication Protocol) |
psk |
Specifies the EAP authentication method type as PSK (Pre-shared Key) |
rsa-public-key |
Specifies the EAP authentication method type as RSA public key protocol |
sim |
Specifies the EAP authentication method type as GSM SIM (Subscriber Identity Module) |
tls |
Specifies the EAP authentication method type as TLS (Transport Layer Security) |
ttls |
Specifies the EAP authentication method type as TTLS (Tunneled Transport Layer Security) |
auth-param |
After specifying the EAP authentication method type, specify the authentication parameters. These parameters depend on the EAP authentication mechanism selected. |
| [cert|hw-token| nfc-secure-elem| none|sim|soft-token| username-password| usim|vendor] | The following parameters are common to all the above authentication parameters:
If setting the authentication type to either non-eap-inner, inner-eap, credential, or tunneleap-credential, define an authentication value that must be shared with the EAP credential validation server resource. If setting the authentication type to either expanded-eap or expanded-inner-eap, set a required authentication vendor ID that must match the one utilized by the EAP server resource. The ID must be 6 characters in length. If required, enter a 2 - 510 character vendor-specific authentication data required for the selected authentication type. Enter the value in the a-FA -F0-9 format. Provide an authentication vendor type, used exclusively for the expanded-eap or expanded-inner-eap authentication types. The vendor type must be 8 characters in length. |
nx9500-6C8809(config-passpoint-policy-test-nai-realm-example)#eap-method 1 ttls auth-param vendor hex 00001E
nx9500-6C8809(config-passpoint-policy-test-nai-realm-example)#eap-method 2 rsa-public-key auth-param credential cert
nx9500-6C8809(config-passpoint-policy-test-nai-realm-example)#show context nai-realm example eap-method 1 ttls auth-param vendor hex 00001E eap-method 2 rsa-public-key auth-param credential cert nx9500-6C8809(config-passpoint-policy-test-nai-realm-example)#exit
nx9500-6C8809(config-passpoint-policy-test)#show context passpoint-policy test access-network-type chargeable-public connection-capability ip-protocol 2 port 10 closed nai-realm example eap-method 1 ttls auth-param vendor hex 00001E eap-method 2 rsa-public-key auth-param credential cert 3gpp mcc 505 mnc 14 nx9500-6C8809(config-passpoint-policy-test)#
