Enforces client load balancing on a WLAN‘s access point radios. When enforced, probe and association requests are not responded to, forcing a client to associate with another access point radio. This feature is disabled by default.
Optional. Allows single band clients to associate even during load balancing
2.4GHz – Enables load balancing across 2.4 GHz channels
5GHz – Enables load balancing across 5.0 GHz channels
This option is enabled by default for 2.4 and 5.0 GHz bands.
band-discovery-intvl <0-10000>
Optional. Configures time interval to discover a client's band capability before connection
<0-10000> – Specify a value from 0 - 10000 seconds. The default is 10 seconds.
capability-ageout-time <0-10000>
Optional. Configures a client's capability ageout interval. This is the time for which a client‘s capabilities are retained in the device‘s internal table. Once this time is exceeded the client‘s capabilities are aged out.
<0-10000> – Specify a value from 0 - 10000 seconds. The default is 3600 seconds.
