no
Profile Config Commands
Negates a command or resets values to their default
Syntax
no [adopter-auto-provisioning-policy-lookup|adoption|adoption-mode|alias| application-policy|area|arp|auto-learn|autogen-uniqueid|autoinstall|bluetooth-detection|bridge|cdp|cluster|configuration-persistence|controller|critical-resource|crypto|database-backup|device-upgrade|diag|dot1x|dpi|dscp-mapping| eguest-server|email-notification|environmental-sensor|events|export|file-sync|floor|gre|http-analyze|interface|ip|ipv6|lacp|l2tpv3|l3e-lite-table|led| led-timeout|legacy-auto-downgrade|legacy-auto-update|lldp|load-balancing| logging|mac-address-table|mac-auth|management-server|memory-profile| meshpoint-device|meshpoint-monitor-interval|min-misconfiguration-recovery-time| mint|misconfiguration-recovery-time|noc|nsight|ntp|otls|offline-duration|power-config|preferred-controller-group|preferred-tunnel-controller|radius|raid| rf-domain-manager|router|spanning-tree|traffic-class-mapping|traffic-shape| trustpoint|tunnel-controller|use|virtual-controller|vrrp|vrrp-state-check|zone| wep-shared-key-auth|service]
Parameters
no <PARAMETERS>
no <PARAMETERS>Removes or reverts this profile‘s settings based on the parameters passed
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-profile-default-rfs4000)#show context
profile rfs4000profile rfs4000 default-rfs4000
 autoinstall configuration
 autoinstall firmware
 crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
 crypto ikev2 policy ikev2-default
 crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
 crypto ikev1 remote-vpn
 crypto ikev2 remote-vpn
 crypto auto-ipsec-secure
 crypto remote-vpn-client
 interface me1
 interface up1
 interface ge1
 interface ge2
 interface ge3
 interface ge4
 interface ge5
 interface ge6
 interface ge7
 interface ge8
 interface wwan1
 interface pppoe1
 use firewall-policy default
 logging on
 service pm sys-restart
 router ospf
 router bgp
 adoption start-delay min 10 max 30
nx9500-6C8809(config-profile-default-rfs4000)#no adopter-auto-provisioning-policy-lookup
nx9500-6C8809(config-profile-default-rfs4000)#no adoption start-delay
 interface me1
 interface up1
 interface ge1
 interface ge2
 interface ge3
 interface ge4
 interface ge5
 interface ge6
 interface ge7
 interface ge8
 interface wwan1
 interface pppoe1
 logging on
 router ospf
 router bgp
