logging
Displays the network's activity log
Syntax
show logging {on <DEVICE-NAME>}
Parameters
logging {on <DEVICE-NAME>}Displays logging information on a specified device
  • <DEVICE-NAME> – Optional. Specify the name of the AP or wireless controller.
NOC-NX9500#show logging
Logging module: enabled
    Aggregation time: disabled
    Console logging: level debugging
    Monitor logging: disabled
    Buffered logging: level warnings
    Syslog logging: level warnings
        Facility: local7
Log Buffer (2096166 bytes):
Feb 09 10:49:16 2018: NOC-NX9500 : %DIAG-4-PWRSPLY_FAIL: Power supply redundancy failure
Feb 09 10:39:11 2018: NOC-NX9500 : %DIAG-4-PWRSPLY_FAIL: Power supply redundancy failure
Feb 09 10:29:06 2018: NOC-NX9500 : %DIAG-4-PWRSPLY_FAIL: Power supply redundancy failure
Feb 09 10:19:01 2018: NOC-NX9500 : %DIAG-4-PWRSPLY_FAIL: Power supply redundancy failure
Feb 09 10:08:55 2018: NOC-NX9500 : %DIAG-4-PWRSPLY_FAIL: Power supply redundancy failure
Feb 09 09:58:49 2018: NOC-NX9500 : %DIAG-4-PWRSPLY_FAIL: Power supply redundancy--More--
NOC-NX9500#
