The configuration of controllers (wireless controllers, service and virtual platforms, and access points) comprises of RF Domains that define regulatory, location, and other relevant policies. At least one default RF Domain is assigned to each controller. RF Domains allow administrators to assign configuration data to multiple devices deployed in a common coverage area, such as in a floor, building, or site. Each RF Domain contains policies that set the Smart RF or WIPS configuration.
RF Domains also enable administrators to override WLAN SSID name and VLAN assignments. This enables the deployment of a global WLAN across multiple sites and unique SSID name or VLAN assignments to groups of access points servicing the global WLAN. This WLAN override eliminates the need to define and manage a large number of individual WLANs and profiles.
WiNG access points only support one RF Domain, which is the default RF Domain. If needed, use this command to override the built-in default RF Domain configuration.nx9500-6C8809#show version NX9500 version 7.1.2.0-08D Copyright (c) 2004-2019 Extreme Networks, Inc. All rights reserved. Booted from primary nx9500-6C8809 uptime is 0 days, 00 hours 31 minutes CPU is Intel(R) Xeon(R) CPU E5645 @ 2.40GHz, No. of CPUs 24 Base ethernet MAC address is B4-C7-99-6C-88-09 System serial number is B4C7996C8809 Model number is NX-9500-100R0-WR nx9500-6C8809#
nx9500-6C8809#show adoption status ---------------------------------------------------------------------------------------------- DEVICE-NAME VERSION CFG-STAT MSGS ADOPTED-BY LAST-ADOPTION UPTIME ---------------------------------------------------------------------------------------------- ap8432-070235 5.9.4.0-015D configured No nx9500-6C8809 0 days 00:27:59 2 days 23:02:09 ap7562-84A224 5.9.4.0-015D configured No nx9500-6C8809 0 days 00:27:57 38 days 14:34:24 ap7532-DF9A4C 5.9.4.0-015D configured No nx9500-6C8809 0 days 00:31:02 15 days 14:25:44 ap505-134038 7.1.0.0-124D configured No nx9500-6C8809 0 days 00:30:49 1 days 03:07:01 ---------------------------------------------------------------------------------------------- Total number of devices displayed: 4 nx9500-6C8809#
In a mixed deployment, with access points running both WiNG 7.1.X and WiNG 5.9.X firmware, we recommend that these APs be placed in separate RF Domains.
rf-domain {<RF-DOMAIN-NAME>|containing <RF-DOMAIN-NAME>}
| rf-domain | Creates a new RF Domain or enters its configuration context |
| <RF-DOMAIN-NAME> | Optional. Specify the RF Domain name (should not exceed 32 characters and should represent the intended purpose). Once created, the name cannot be edited. |
| containing <RF-DOMAIN-NAME> | Optional. Identifies an existing RF Domain that contains a specified sub-string in the domain name
nx9500-6C8809(config)#rf-domain ecospace nx9500-6C8809(config-rf-domain-ecospace)#? RF Domain Mode commands: alias Alias channel-list Configure channel list to be advertised to wireless clients contact Configure the contact control-vlan VLAN for control traffic on this RF Domain controller-managed RF Domain manager for this domain will be an adopting controller country-code Configure the country of operation geo-coordinates Configure geo coordinates for this device layout Configure layout location Configure the location location-server Configuration ExtremeLocation server location-tenantid Set ExtremeLocation tenant id mac-name Configure MAC address to name mappings no Negate a command or set its defaults nsight-sensor Enable sensor for Nsight override-smartrf Configured RF Domain level overrides for smart-rf override-wlan Configure RF Domain level overrides for wlan sensor-server AirDefense sensor server configuration stats Configure the stats related setting timezone Configure the timezone tree-node Configure tree node under which this rf-domain appears use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-rf-domain-ecospace)#
| no | Removes an existing RF Domain. Specify the RF Domain name. |
Section contents:
