Ethernet ports (Eth0 and Eth1) automatically negotiate half- and full-duplex connections with the connecting device.
Eth0 is 100/1000/2500 BASE-T
Eth1 is 10/100/1000 BASE-T
These ports are autosensing and adjust to straight-through and crossover standard Cat5 or better Ethernet cables automatically. The access point receives power through an Ethernet connection to the ETH0 port from power sourcing equipment (PSE) that is compatible with the 802.3at and 802.3at standards.
One USB port
Use the USB port to connect USB-based beacons such as iBeacon and Internet of Things (IoT) devices.
One micro USB console port
You can order a micro USB console adapter for the AP410C access point here.
One reset button
One security slot
Tip
The best practice is to use Kensington® locks for locking the device.
Operating temperature: 0 °C to +40 °C (+32 °F to +104 °F)
Storage temperature: −40 °C to +70 °C (−40 °F to +158 °F)
