bridging-mode
Configures the mode used to bridge
packets to and from a WLAN. Use this command to define which VLANs are bridged, and how
local VLANs are bridged between the wired and wireless sides of the network.
Access
Points: AP3000 /X, AP5010 , AP310i/e , AP410i/e , AP505i , AP510i , AP510e , AP560i , AP7602 , AP7612 , AP7622 , AP7632 , AP7662 , AP8163 , AP8533 . Service Platforms: NX5500, NX7500, NX9500, NX9600 Virtual Platforms : CX9000, VX9000
Syntax
bridging-mode [local|tunnel]
Parameters
bridging-mode Configures bridging mode on this WLAN. The options are
local and tunnel . local Bridges packets between WLAN and local ethernet
ports. This is the default mode. tunnel Tunnels packets to other devices (typically a
wireless controller or service platform)
nx9500-6C8809 (config-wlan-test)#bridging-mode local
nx9500-6C8809 (config-wlan-test)#show context
wlan test
ssid test
bridging-mode local
encryption-type none
authentication-type eap
accounting syslog host 172.16.10.4 port 2
acl exceed-rate wireless-client-denied-traffic 20 disassociate
