Negates a command or reverts values to their default. When used in the config MiNT policy mode, the no command resets or reverts the following global MiNT policy parameters: routing level, MTU, router packet priority, and UDP or IP encapsulation settings.
no [level|lsp|mtu|router|udp]
no level 2 area-id
no lsp checksum
no mtu
no router packet priority
no udp port <LINE-SINK>
no <PARAMETERS>
no <PARAMETERS> | The no command resets or reverts the following global MiNT policy parameters: routing level, MTU, router packet priority, and UDP or IP encapsulation settings. |
The following example shows the global Mint Policy parameters before the ‘no‘ commands are executed:
nx9500-6C8809(config-mint-policy-global-default)#show context mint-policy global-default udp port 1024 mtu 996 level 2 area-id 2000 sign-unknown-device security-level control-and-data rejoin-timeout 1000 nx9500-6C8809(config-mint-policy-global-default)#
nx9500-6C8809(config-mint-policy-global-default)#no level 2 area-id
nx9500-6C8809(config-mint-policy-global-default)#no mtu
nx9500-6C8809(config-mint-policy-global-default)#no udp port
The following example shows the global Mint Policy parameters after the ‘no‘ commands are executed:
nx9500-6C8809(config-mint-policy-global-default)#show context mint-policy global-default sign-unknown-device security-level control-and-data rejoin-timeout 1000 nx9500-6C8809(config-mint-policy-global-default)#
