Configures the mode of adoption in an access point profile. This command is also applicable to the device configuration context.
By default, any WiNG AP, on being powered-up for the first time, starts the following auto-discovery process. The AP:
Moves to MLCP_DISCOVERY state and tries to discover a local controller. If a local controller is found, it
adopts to the controller, and
marks itself as “local-controller” adopted, and
moves to the MLCP_MODE.
If a local controller is not found, the AP switches to the CLOUD_DISCOVERY state, and tries connecting to the ExtremeCloud. If the AP succeeds in connecting to the cloud, it
marks itself as “cloud-adopted”, and
moves to the CLOUD_MODE.
If the AP is unable to discover and adopt to the ExtremeCloud, it switches to the WS_CONTROLLER_DISCOVERY state, and tries connecting to the WebSocket (WS) Controller. If it succeeds in connecting to the ws_controller, it
marks itself as “ws-controller-adopted”, and
moves to the WS_CONTROLLER_MODE.
The AP continues to switch between the three discovery states (local controller, cloud, and ws_controller) until it gets adopted.
Once adopted, an AP‘s adoption mode does not change unless,
It is changed from the controller‘s CLI (using the adoption-mode command), the Cloud dashboard, or the WS controller dashboard.
If the AP is reverted to factory settings, in which case the AP starts the auto-discovery process on bootup.
cloud – Sets the adoption-mode to Extreme Cloud. The factory-default, management server setting, in WiNG AP profiles contexts, points to the Extreme Cloud Web address. If the adoption-mode is set to cloud, the AP on coming up, will search for and adopt to the ExtremeCloud.
controller – Sets the adoption mode to the local WiNG controller. This is the default setting. Note, APs with the ‘controller > host > configuration‘ specified are marked as local-controller APs and never try adopting to the CLOUD or WS-Controller
ws-controller – Sets the adoption mode to the Edge Application Engine (EAE) ws-controller. If selecting this option, use the ‘management-server‘ command to configure the EAE controller‘s IP address or hostname. For information on configuring the management-server, see management-server.
Note: Alternately, the AP auto-adopts to the WS controller, if its receives DHCP IP address, and the DHCP option 191 poo1 string configuration is as shown in the following examples:
In the DHCP server policy, define an alias for option 191:
