The command ‘ip igmp snooping‘ can be
configured under bridge VLAN context also. For example: nx9500-6C8809(config-device
B4-C7-99-6C-88-09-bridge-vlan-1)#ip igmp snooping forward-unknown-multicast
Configures failover to the gateway (with next higher priority) when the current default gateway is unreachable (In case of multiple default gateways). This option is enabled by default.
<HOST-ALIAS-NAME>
Configures the host alias mapped to the required default gateway
<HOST-ALIAS-NAME> – Specify the host alias name (should be existing and configured). Host alias names begin with a ‘$‘.
dhcp-client <1-8000>
– Defines a priority for the default gateway acquired by the DHCP
client on the VLAN interface. The default setting is 1000.
static-route
<1-8000> – Defines the weight (priority) assigned to this static
route versus others that have been defined to avoid potential
congestion. The default setting is 100.
The following keyword is common to ‘dhcp-client‘ and ‘static-route‘ parameters:
<1-8000> – Specify
the priority from 1 - 8000 (where 1 is the highest priority and 8000
is the lowest priority )
ip [dns-server-forward|domain-lookup|domain-name <DOMAIN-NAME>|name-server <IP>|routing]
ip
Configures IPv4 routing components
dns-server-forward
Enables DNS forwarding. This command enables the forwarding of DNS queries to DNS servers outside of the network. This option is disabled by default.
domain-lookup
Enables domain lookup. When enabled, human friendly domain names are converted into numerical IP destination addresses. The option is enabled by default.
Configures a default domain name
<DOMAIN-NAME> – Specify a name for the DNS (should not exceed 64 characters in length).
name-server <IP>
Configures the name server‘s IP address
<IP> – Specify the IP address of the name server.
routing
Enables IP routing of logically addressed packets from their source to their destination. IPv4 routing is enabled by default.
ip dhcp client [hostname|persistent-lease]
ip
dhcp
Configures the DHCP client and host
client [hostname| persistent-lease]
Sets the DHCP client
hostname – Includes the hostname in the DHCP lease for the requesting client. This option is enabled by default.
persistent-lease – Retains the last lease across reboots if the DHCP server is unreachable. A persistent DHCP lease assigns the same IP address and other network information to the device each time it renews its DHCP lease. This option is disabled by default.
ip igmp snooping {fast-leave|forward-unknown-multicast}
ip
fats-leave
Optional. Enables fast leave processing. When enabled, leave messages are processed quickly, preventing the host from receiving further traffic. Should be configured for one (wired) host network only. This option is disabled by default.
This feature is supported only on the AP7502, AP8533 model access points.
igmp snooping
Optional. Enables unknown multicast data packets to be flooded in the specified VLAN. This option is disabled by default.
static – Specifies static NAT local to global mapping
<ACTUAL-IP> – Specify the actual inside IP address to map.
<1-65535> [tcp|udp]
<1-65535> – Configures the actual outside port. Specify a value from 1 - 65535.
tcp – Configures the TCP port
udp – Configures the UDP port
<NATTED-IP> <1-65535>
Enables configuration of the outside natted IP address
<NATTED-IP> – Specify the outside natted IP address.
<1-65535> – Optional. Configures the outside natted port. Specify a value from 1 - 65535.
ip nat [inside|outside] source list <IP-ACCESS-LIST-NAME> interface
[<INTERFACE-NAME>|pppoe1|vlan <1-4094>|wwan1] [(address <IP>|interface <L3-IF-NAME>|overload|
pool <NAT-POOL-NAME>)]
ip
nat
Configures the NAT parameters
[inside|outside]
Configures inside and outside IP access list
source list
Configures an access list describing local addresses
<IP-ACCESS-LIST-NAME> – Specify a name for the IP access list.
Selects an interface to configure. Select a layer 3 router interface or a VLAN interface.
<INTERFACE-NAME> – Selects a layer 3 interface. Specify the layer 3 router interface name.
vlan – Selects a VLAN interface
<1-4094> – Set the SVI VLAN ID of the interface.
pppoe1 – Selects PPP over Ethernet interface
wwan1 – Selects Wireless WAN interface
address <IP>
The following keyword is recursive and common to all interface types:
address <IP> – Configures the interface IP address used with NAT
interface <L3-IF-NAME> – Configures a wireless controller or service platform‘s VLAN interface
<L3IFNAME> – Specify the SVI VLAN ID of the interface.
overload
overload – Enables use of global address for many local addresses
pool <NAT-POOL-NAME> – Specifies the NAT pool
<NAT-POOL-NAME> – Specify the NAT pool name.
ip route <IP/M> [<IP>|<HOST-ALIAS-NAME>]
ip
route
Configures the static routes
<IP/M>
Specify the IP destination prefix in the A.B.C.D/M format.
<IP>
Specify the IP address of the gateway.
<HOST-ALIAS-NAME>
NOC-NX9500(config-profile-testNX9000)#ip default-gateway 10.234.160.5
NOC-NX9500(config-profile-testNX9000)#ip dns-server-forward
NOC-NX9500(config-profile-testNX9000)#ip nat inside source list BROADCAST-MULTIC
AST-CONTROL precedence 1 interface vlan 1 pool NATPool1 overload
NOC-NX9500(config-profile-testNX9000-nat-pool-NATPool1)#?
Nat Policy Mode commands:
address Specify addresses for the nat pool
no Negate a command or set its defaults
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
