frictionless-onboarding
Enables wireless clients, associated with guest WLANs, to self-register with the ExtremeGuest server. In other words, this feature enables frictionless onboarding of guest users to the ExtremeGuest server.
It also provides an integration API, as a means of onboarding guest users through a loyalty application.
To enable this feature, in the Guest WLAN (using this captive-portal), enable MAC authentication and set the registration mode to ‘device‘. For details on enabling frictionless onboarding, see Examples.
Syntax
Parameters
None
The following configurations are required to enable frictionless onboarding of guest users to the ExtremeGuest server:
  1. Create a captive-portal:
    NX9500-EGuest(config)#captive-portal EGuest
    NX9500-EGuest(config-captive-portal-EGuest)#
    1. Set the access-type as registration.
      NX9500-WC-EGuest(config-captive-portal-EGuest)#access-type registration
      This sets the guest user access and authentication mode to self-registration.
    2. Enable frictionless-onboarding.
      NX9500-WC-EGuest(config-captive-portal-EGuest)#frictionless-onboarding
      This enables auto-redirection of guest users to the ExtremeGuest server, where the user‘s MAC address is registered. Registered devices, on subsequent logins, are provided immediate access without interaction with Splash pages.
    3. Configure Localization URL.
      NX9500-WC-EGuest(config-captive-portal-test)#localization fqdn local.guestaccess.com
      When configured, the defined URL is triggered from a mobile application to derive location information from the wireless network so that an application can be localized to a particular store or region.
      NX9500-WC-EGuest(config-captive-portal-Guest)#show context
       webpage internal registration field city type text enable label "City" placeholder "Enter City"
       webpage internal registration field street type text enable label "Address" placeholder "123 Any Street"
       webpage internal registration field name type text enable label "Full Name" placeholder "Enter First Name, Last Name"
       webpage internal registration field zip type number enable label "Zip" placeholder "Zip"
       webpage internal registration field via-sms type checkbox enable title "SMS Preferred"
       webpage internal registration field mobile type number enable label "Mobile" placeholder "Mobile Number with Country code"
       webpage internal registration field age-range type dropdown-menu enable label "Age Range" title "Age Range"
       webpage internal registration field email type e-address enable mandatory label "Email" placeholder "you@domain.com"
       webpage internal registration field via-email type checkbox enable title "Email Preferred"
      This is an example fqdn URl.
  2. Create a WLAN with the following settings:
    1. Set authentication-type as ‘mac‘.
      NX9500-WC-EGuest(config-wlan-EGuest)#authentication-type mac
      When configured, enables MAC authentication of guest users.
    2. Enable device registration.
      NX9500-WC-EGuest(config-wlan-EGuest)#registration device group-name test expiry-time 300
      When enabled, guest users' device MAC addresses are registered in the database. Registered devices are provided immediate access on subsequent logins.
    3. Set guest-registration as external.
      NX9500-WC-EGuest(config-wlan-EGuest)#registration external follow-aaa
      This enables forwarding of guest registration and authentication requests to an external authentication server resource, specified in an AAA policy.
      Note, in this scenario, the external resource is the ExtremeGuest server.
      Execute the command in the following step to specify the AAA Policy.
    4. Apply an AAA Policy to the WLAN.
      NX9500-WC-EGuest(config-wlan-EGuest)#use aaa-policy guest
      When applied, registration and authentication requests are forwarded to the authentication server configured in the specified AAA Policy.
      In the AAA policy, ensure that the authentication server configuration points to the ExtremeGuest server.
    5. Enable captive-portal enforcement.
      NX9500-WC-EGuest(config-wlan-EGuest)#captive-portal-enforcement fall-back
      When enabled, captive-portal validation is enforced on clients requesting access. Fall-back is an optional parameter that enforces captive-portal authentication only on failure of WLAN authentication.
    6. Use the captive-portal configured in Step 1 in the WLAN..
      NX9500-WC-EGuest(config-wlan-EGuest)#use captive-portal EGuest
      NX9500-WC-EGuest(config-wlan-EGuest)#show context
      wlan EGuest
       ssid eguest
       bridging-mode local
       encryption-type none
      This is the captive-portal used with this WLAN for captive-portal validation of guest users.
Related Commands
noDisables frictionless-onboarding of guest users to the ExtremeGuest server
