connect
Begins a console connection to a remote device using the remote device's MiNT ID or name
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.
Syntax
connect [mint-id <MINT-ID>|<REMOTE-DEVICE-NAME>]
Parameters
mint-id <MINT-ID>
Connects to the remote system using its MiNT ID
  • <MINT-ID> – Specify the remote device MiNT ID.
Connects to the remote system using its name
  • <REMOTE-DEVICE-NAME> – Specify the remote device name.
ap510-133B3B>connect
ap510-133B3B ap510-13452A default/ap510-133B3B default/ap510-13452A mint-id
ap510-133B3B>
ap510-133B3B>connect ap510-13452A
Entering character mode
Escape character is '^]'.
AP510 release 7.0.0.0-0009X
ap510-13452A login:
