captive-portal-mode-commands
The following table summarizes captive portal configuration mode commands:
Table 1. Captive-Portal-Mode Commands
Command
Description
access-time
Defines client access time. It is used when no session time is defined in the RADIUS response.
access-type
Configures a captive portal access type
accounting
Enables a captive portal accounting records
bypass
Enables bypassing of captive portal detection requests
connection-mode
Configures a captive portal's connection mode
custom-auth
Configures custom user information
data-limit
Enforces data limit on captive portal clients
frictionless-onboardingEnables wireless clients, associated with guest WLANs, to self-register with the ExtremeGuest server.
inactivity-timeout
Defines an inactivity timeout in seconds
ipv6Configures the IPv6 address of the internal captive portal server
localizationConfigures an FQDN address string that enables the client to receive localization parameters. This command also allows the configuration of a response message.
logout-fqdn
Clears the logout FQDN address
no
Reverts the selected captive portal‘s settings or resets settings to default
oauthEnables OAuth-based authentication support on the captive portal. When enabled, OAuth allows captive-portal users to sign in to guest WLANs using their Facebook or Google credentials.
php-helperConfigures a PHP helper to serve the captive portal PHP splash pages to guest users using social-media to login to the captive portal.
post-authentication-vlan
Assigns a post authentication RADIUS VLAN for this captive portal users
radius-vlan-assignment
Assigns a RADIUS VLAN for this captive portal
redirection
Enables redirection of client connections to specified destination ports
report-royalty-applicationEnables detection of captive portal client loyalty application presence and stores this information in the captive portal user database
server
Configures the captive portal server settings
simultaneous-users
Specifies a username used by a MAC address pool
terms-agreement
Enforces the user to agree to terms and conditions (included in the login page) for captive portal access
use
Associates an AAA policy and a DNS whitelist with a captive portal
webpage
Configures captive portal Web page settings
webpage-auto-upload
Enables automatic upload of advanced Web pages on a captive portal
webpage-location
Specifies the location of Web pages used for captive portal authentication
welcome-backEnables the provision of direct Internet access to once-registered, captive-portal guest users on subsequent log-ins
configuring device registration with dynamic vlan assignmentProvides the configuration details required to enable device registration with dynamic VLAN assignment in a multi-vendor environment.
Configuring WeChat Wi-Fi hotspot support in WiNG captive portalProvides configuration details required to enable WeChat Wi-Fi hotspot support in WiNG captive portal.
configuring ExtremeGuest captive portalProvides the basic configurations required to deploy an ExtremeGuest setup
