dns-whitelist <DNS-WHITELIST-NAME>
<DNS-WHITELIST-NAME> |
Specify the DNS whitelist name. If the whitelist does not exist, it is created. |
nx9500-6C8809(config)#dns-whitelist test nx9500-6C8809(config-dns-whitelist-test)#? DNS Whitelist Mode commands: no Negate a command or set its defaults permit Match a host clrscr Clears the display screen commit Commit all changes made in this session end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-dns-whitelist-test)#
| no |
Removes an existing DNS Whitelist |
Section contents:
