data-rates
Configures the 802.11 rates supported on this WLAN
Syntax
data-rates [2.4GHz|5GHz|6GHz]
data-rates 2.4GHz [b-only|bg|bgn|custom|default|g-only|gn]
data-rates 2.4GHz custom [1|11|12|18|2|24|36|48|5.5|54|6|9|basic-1|basic-11|basic-12|
basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|
basic-mcs-1s|mcs-1s|mcs-2s|mcs-3s|basic-mcs-1s|basic-mcs0-7|mcs-1s|mcs-2s|mcs-3s|
mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
data-rates 5GHz [a-only|an|custom|default]
data-rates 5GHz custom [12|18|24|36|48|54|6|9|basic-1|basic-11|basic-12|basic-18|
basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|basic-mcs-1s|
basic-mcs0-7|mcs-1s|mcs2s|mcs3s|mcs4s|mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
data-rates 6GHz (ax|default)
data-rates 6GHz custom {1s|2s|3s|4s|LIST|basic-6|basic-9|basic-12|basic-18|basic-24|basic-36|
basic-48|basic-54}
data-rates 6GHz custom {6|9|12|18|24|36|48|54|basic-1|basic-2|basic-5.5|basic-6|basic-9|basic-11|
basic-12|basic-18|basic-24|basic-36|basic-48|basic-54|mcs}
Parameters
data-rates 2.4GHz [b-only|bg|bgn|default|g-only|gn]
data-ratesSpecifies the 802.11 rates supported when mapped to a 2.4 GHz radio
b-onlyUses rates that support only 11b clients
bgUses rates that support both 11b and 11g clients
bgnUses rates that support 11b, 11g and 11n clients
defaultUses the default rates configured for a 2.4 GHz radio
g-onlyUses rates that support operation in 11g only
gnUses rates that support 11g and 11n clients
data-rates 5GHz [a-only|an|default]
data-ratesSpecifies the 802.11 rates supported when mapped to a 5.0 GHz radio
a-onlyUses rates that support operation in 11a only
anUses rates that support 11a and 11n clients
defaultUses default rates configured for a 5.0 GHz
data-ratesSpecifies the data rates supported when mapped to a 6.0 GHz radio
axUses rates that support operation in 11ax only
defaultUses default rates configured for a 6.0 GHz
basic-12|basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|
basic-9|basic-mcs-1s|mcs-1s|mcs-2s|mcs-3s|basic-mcs-1s|basic-mcs0-7|mcs-1s|mcs-2s|
mcs-3s|mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
data-rates [2.4GHz|5GHz|6GHz]Specifies the 802.11 rates supported when mapped to a 2.4 GHz, 5.0 GHz, or |6GHz radio
customConfigures a data rates list by specifying each rate individually. Use 'basic-' prefix before a rate to indicate it is used as a basic rate (For example, 'data-rates custom basic-1 basic-2 5.5 11').
The data-rates for 2.4 GHz and 5.0 GHz channels are the same with a few exceptions. The 2.4 GHz channel has a few extra data rates: 1, 11, 2, and 5.5.
1,11,2,5.5The following data rates are specific to the 2.4 GHz channel:
  • 1 – 1-Mbps
  • 11 – 11-Mbps
  • 2 – 2-Mbps
  • 5.5 – 5.5-Mbps
12,18,24,36,48,54,6,9, basic-1,basic-11, basic-12,basic-18, basic-2, basic-36,basic-48, basic-5.5, basic-54,basic-6, basic-9, basic-mcs0-7,mcs0-15, mcs0-7,mcs8-15The following data rates are common to both the 2.4 GHz and 5.0 GHz channels:
  • 12 – 12 Mbps
  • 18 – 18-Mbps
  • 24 – 24 Mbps
  • 36 – 36-Mbps
  • 48 – 48-Mbps
  • 54 – 54-Mbps
  • 6 – 6-Mbps
  • 9 – 9-Mbps
  • basic-1 – basic 1-Mbps
  • basic-11 – basic 11-Mbps
  • basic-12 – basic 12-Mbps
  • basic-18 – basic 18-Mbps
  • basic-2 – basic 2-Mbps
  • basic-36 – basic 36-Mbps
  • basic-48 – basic 48-Mbps
  • basic-5.5 – basic 5.5-Mbps
  • basic-54 – basic 54-Mbps
  • basic-6 – basic 6-Mbps
  • basic-9 – basic 9-Mbps
  • basic-mcs-1s – Modulation and coding scheme data rates for 1 Spatial Stream
  • mcs-1s – Applicable to 1-spatial stream data rates
  • mcs-2s – Applicable to 2-spatial stream data rates
  • mcs-3s – Applicable to 3-spatial stream data rates
nx9500-6C8809(config-wlan-test)#data-rates 2.4GHz gn
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode local
 encryption-type none
 authentication-type eap
 accounting syslog host 172.16.10.4 port 2
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 captive-portal-enforcement fall-back
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 broadcast-dhcp validate-offer
Related Commands
no (wlan-config-mode)Resets the 802.11 data rates supported on a WLAN for the 2.4 GHz or 5.0 GHz radios
