About AAA Policy
An AAA policy enables administrators to define access control settings governing network permissions. External RADIUS and LDAP servers (AAA servers) also provide user database information and user authentication data. Each WLAN maintains its own unique AAA configuration.
AAA provides a modular way of performing the following services:
Authentication — Provides a means for identifying users, including login and password dialog, challenge and response, messaging support and (depending on the security protocol), encryption. Authentication is the technique by which a user is identified before allowed access to the network. Configure AAA authentication by defining a list of authentication methods, and then applying the list to various interfaces. The list defines the authentication schemes performed and their sequence. The list must be applied to an interface before the defined authentication technique is conducted.
Authorization — Authorization occurs immediately after authentication. Authorization is a method for remote access control, including authorization for services and individual user accounts and profiles. Authorization functions through the assembly of attribute sets describing what the user is authorized to perform. These attributes are compared to information contained in a database for a given user and the result is returned to AAA to determine the user's actual capabilities and restrictions. The database could be located locally or be hosted remotely on a RADIUS server. Remote RADIUS servers authorize users by associating attribute-value (AV) pairs with the appropriate user. Each authorization method must be defined through AAA. When AAA authorization is enabled it‘s applied equally to all interfaces.
Accounting — Collects and sends security server information for billing, auditing, and reporting user data; such as start and stop times, executed commands (such as PPP), number of packets, and number of bytes. Accounting enables wireless network administrators to track the services users are accessing and the network resources they are consuming. When accounting is enabled, the network access server reports user activity to a RADIUS security server in the form of accounting records. Each accounting record is comprised of AV pairs and is stored locally on the access control server. The data can be analyzed for network management, client billing, and/or auditing. Accounting methods must be defined through AAA. When AAA accounting is activated, it is applied equally to all interfaces on the access servers.
Use the (config) instance to configure AAA policy commands. To navigate to the config-aaa-policy instance, use the following commands:
nx9500-6C8809
(config)#aaa-policy test
nx9500-6C8809
(config-aaa-policy-test)#?
AAA Policy Mode commands:
  accounting           Configure accounting parameters
  attribute            Configure RADIUS attributes in access and accounting
                       requests
  authentication       Configure authentication parameters
  health-check         Configure server health-check parameters
  mac-address-format   Configure the format in which the MAC address must be
                       filled in the Radius-Request frames
  no                   Negate a command or set its defaults
  proxy-attribute      Configure radius attribute behavior when proxying
                       through controller or rf-domain-manager
  server-pooling-mode  Configure the method of selecting a server from the
                       pool of configured AAA servers
  use                  Set setting to use
  clrscr               Clears the display screen
  commit               Commit all changes made in this session
  do                   Run commands from Exec mode
  end                  End current mode and change to EXEC mode
  exit                 End current mode and down to previous mode
  help                 Description of the interactive help system
  revert               Revert changes
--More--
nx9500-6C8809
ap505-13403B(config-aaa-policy-test)#?
                       requests
  service              Service Commands
  show                 Show running system information
  write                Write running configuration to memory or terminal
