mac-authentication
Enables MAC authentication. When enabled, the system uses cached credentials (RADIUS server lookups are skipped) to authenticate clients.
Syntax
mac-authentication [cached-credentials|enforce-always]
Parameters
mac-authenticationEnables MAC authentication on this WLAN and configures related parameters
cached-credentialsUses cached credentials to skip RADIUS lookups. This option is disabled by default.
enforce-alwaysEnforces MAC authentication on this WLAN. When enabled, MAC authentication is enforced, each time a client logs in, even when the authentication type specified (using the authentication-type command) is not MAC authentication. This option is disabled by default.
rfs4000-229D58(config-wlan-test)#mac-authentication cached-credentials
Related Commands
no (wlan-config-mode)Disables MAC authentication related parameters: Disables use of cached credentials to skip RADIUS lookups, or disables enforcement of MAC authentication on this WLAN.
