Use this command to configure the parameters of authentication mode specified using the ‘security-mode‘ keyword. This command also allows you to set a unicast and broadcast key rotation interval.
Enables periodic rotation of encryption keys used for broadcast and unicast traffic
broadcast
Configures key rotation interval for broadcast and multicast traffic. This option is disabled by default.
When enabled, the key indices used for encrypting/decrypting broadcast traffic is alternatively rotated based on the defined interval. Key rotation enhances the broadcast traffic security on the WLAN.
unicast
Configures key rotation interval for unicast traffic. This option is disabled by default.
<30-86400>
Configures key rotation interval from 30 - 86400 seconds for unicast or broadcast transmission
wpa2 psk [0 <SECRET>|2 <SECRET>|<SECRET>]
wpa2 psk
Configures the shared key for authentication mode PSK. If the security mode is set as ‘psk‘ using the ‘security-mode‘ keyword, use this command to configure the pre-shared key.
secret [0 <SECRET>| 2 <SECRET>|<SECRET>]
Configures the PSK used to authenticate this meshpoint with other meshpoints in the network
0 <SECRET> – Configures a clear text secret
2 <SECRET> – Configures an encrypted secret
<SECRET> – Specify the secret key. The pre-shared key can be in ASCII (8 to 63 characters in length) or Hexadecimal (not exceeding 64 characters in length) formats.
Configures the 802.1X/EAP based authentication type for this meshpoint. If the security mode is set as ‘eap‘ using the ‘security-mode‘ keyword, use this command to specify the EAP type. The options are: peap-mschapv2 and tls.
auth-type [peap-mschapv2|tls]
Specifies the EAP authentication type. The options are:
peap-mschapv2 – Configures EAP authentication type as PEAP (Protected Extensible Authentication Protocol) with default auth type MSCHAPv2. This is the default setting.
If using auth-type as ‘peap-mschapv2‘, use the ‘peap-mschapv2‘ keyword to configure user credentials and trustpoint details.
tls – Configures EAP authentication type as TLS (Transport Layer Security)
If using auth-type as ‘tls‘, use the ‘tls‘ keyword to configure trustpoint details.
Note: The certificate should be issued from an Enterprise or public certificate authority to allow 802.1X clients to validate the identity of the authentication server prior to forwarding credentials.
identity <WORD>
Configures identity to be used during phase1 authentication
<WORD> – Enter a string up to 256 characters in length (this should not be actual identity of user but some anonymous/bogus username).
