To enforce database authentication, enable authentication on the database-policy, and configure the username and password required to access the database. Note, this command is part of a set of configurations that are required to enable authentication. For more information on the entire set of configurations, see Example: Enabling Database Authentication.
database-policy <DATABASE-POLICY-NAME>
| database-policy <DATABASE-POLICY-NAME> | Specify the database policy name. If the policy with the specified name does not exist, it is created. |
nx9500-6C8809(config)#database-policy test nx9500-6C8809(config-database-policy-test)#? Database Policy Mode commands: authentication Database authentication no Negate a command or set its defaults replica-set Replica Set shutdown Disable database server clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-database-policy-test)#
| no | Removes an existing database-policy |
| database-client-policy global-config | Documents database-client policy configuration commands. The database-client-policy configures the IP address or hostname of the database host, and is used on the EGuest server‘s device context. |
| use (profile/device-config-mode-commands) | Uses a database-client-policy in the VX9000's device or profile context |
| database | Drops or repairs a database. Also provides database keyfile management capabilities. If enforcing authenticated access to the database, use this command to generate, export, import, and zerzoise the keyfile. |
Section contents:
