An EX3500 policy map contains one or more EX3500 QoS class maps traffic classifications (existing and configured) and can be attached to multiple interfaces. Create a EX3500 policy map, and then use the class parameter to configure policies for traffic that matches the criteria defined in the EX3500 QoS class map policy. For more information, see match.
ex3500-qos-policy-map <EX3500-QOS-POLICY-MAP-NAME>
| <EX3500-QOS-POLICY-MAP-NAME> | Specify the EX3500 policy map name |
nx9500-6C8809(config)#ex3500-qos-policy-map testPolicyMap EX3500(config-ex3500-qos-policy-map-testPolicyMap)#? nx9500-6C8809_Qos_policy_map Mode commands: class Defines a traffic classification for the policy description Policy-map description no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap)#
| no (ex3500-qos-policy-map) | Removes an existing EX3500 QoS policy map |
Section contents:
