Verifies
firmware versions before adopting. This option is enabled by
default.
cluster
Verifies
firmware versions before clustering. This option is enabled by
default.
full
Allows adoption
or clustering when the first four octets of the firmware versions match (for
example 5.9.3.0)
major
Allows adoption
or clustering when the first two octets of the firmware versions match (for
example 5.9)
minor
Allows adoption
or clustering when the first three octets of the firmware versions match
(for example 5.9.3)
none
Allows adoption
or clustering between any firmware versions
strict
Allows adoption
or clustering only when firmware versions exactly match (for example
5.9.3.0-010D). This is the default setting for both ‘adoption‘ and ‘cluster‘
options.
nx9500-6C8809(config-profile-test-nx5500)#enforce-version cluster full
nx9500-6C8809(config-profile-test-nx5500)#enforce-version adoption major
nx9500-6C8809(config-profile-test-nx5500)#show context
profile nx5500 test-nx5500
no autoinstall configuration
no autoinstall firmware
crypto ikev1 policy ikev1-default
isakmp-proposal default encryption aes-256 group 2 hash sha
interface pppoe1
use firewall-policy default
service pm sys-restart
router ospf
router bgp
dot1x system-auth-control
dot1x use aaa-policy OnBoarding
