Configures the total number of times a message is transmitted towards a non-responsive client
<1-5> – Specify a value from 1 - 5. The default is 2.
init-wait <5-1000000>
Configures a minimum wait-time period, in microseconds, before the first handshake message is transmitted from the AP. This option is disabled by default.
<5-1000000> – Specify a value from 5 - 1000000 microseconds.
priority [high|normal]
Configures the relative priority of handshake messages compared to other data traffic
high – Treats handshake messages as high priority packets on a radio. This is the default setting.
normal – Treats handshake messages as normal priority packets on a radio
timeout <10-5000> <10-5000>
Configures the timeout period, in milliseconds, for a handshake message to retire. Once this period is exceeded, the handshake message is retired.
<10-5000> – Specify a value from 10 - 5000 millisceonds. The default is 500 milliseconds.
<10-5000> – Optional. Configures a different timeout between the second and third attempts'
Configures parameters related to periodic rotation of encryption keys. The periodic key rotation parameters are broadcast, multicast, and unicast traffic.
broadcast <30-86400>
Configures the periodic rotation of keys used for broadcast and multicast traffic. This parameter specifies the interval, in seconds, at which keys are rotated. This option is disabled by default.
<30-86400> – Specify a value from 30 - 86400 seconds.
unicast <30-86400>
Configures a periodic interval for the rotation of keys, used for unicast traffic. This option is disabled by default.
wpa-wpa2 psk [0 <LINE>|2 <LINE>|<LINE>]
wpa-wpa2
Modifies TKIP-CCMP (WPA/WPA2) related parameters
psk
Configures a pre-shared key.
0 <LINE>
Configures a clear text key
2 <LINE>
Configures an encrypted key
<LINE>
Enter the pre-shared key either as a passphrase not exceeding 8 - 63 characters, or as a 64 character (256bit) hexadecimal value.
wpa-wpa2 tkip-countermeasures holdtime <0-65535>
wpa-wpa2
Modifies TKIP-CCMP (WPA/WPA2) parameters
Configures a hold time period for implementation of TKIP counter measures
holdtime <0-65535>
Configures the amount of time a WLAN is disabled when TKIP counter measures are invoked
<0-65535> – Specify a value from 0 - 65536 seconds. <0-65535> – Specify a value from 0 - 65535 seconds. The default is 60 seconds.
hash-to-element
Enable the use of SAE Hash-to-Element for password element generation.
