Access Points — AP 6522, AP 6532, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP-7562, AP7632, AP7662, AP-8432, AP8533
no [acs|exclude|hysteresis|monitor|path-method|preferred|root|root-select]
no acs [channel-hold-time|channel-switch-delta|channel-width|ocs-duration| ocs-frequency|path-min|path-threshold|preferred-interface-tolerance-period| preferred-radio-interface|priority-meshpoint|sample-count|snr-delta| signal-threshold|tolerance-period] [2.4GHZ|5GHz]
no exclude wired-peer mint-level-1
no hysteresis [min-threshold|period|root-sel-snr-delta|snr-delta]
no monitor [critical-resource|primary-port-link-loss]
no [path-method|root {select-method}]
no root-select cost-root
no preferred [interface|root|neighbor]
no <PARAMETERS>
no <PARAMETERS> | Removes or reverts this meshpoint device settings to default based on the parameters passed |
nx9500-6C8809 (config-profile-testAP8432-meshpoint-test)#show context meshpoint-device test name test root preferred root 22-33-44-55-66-77 preferred neighbor 11-22-33-44-55-66 preferred interface 5GHz monitor critical-resource action no-root nx9500-6C8809 (config-profile-testAP8432-meshpoint-test)#
nx9500-6C8809
(config-profile-testAP8432-meshpoint-test))#no monitor critical-resource
nx9500-6C8809
(config-profile-testAP8432-meshpoint-test)#no preferred neighbor
nx9500-6C8809
(config-profile-testAP8432-meshpoint-test)#no root
nx9500-6C8809
(config-profile-testAP8432-meshpoint-test)#no preferred interface
nx9500-6C8809 (config-profile-testAP8432-meshpoint-test)#show context meshpoint-device test name test no root preferred root 22-33-44-55-66-77 nx9500-6C8809 (config-profile-testAP8432-meshpoint-test)#
