location-policy
Creates a Location policy and enters its configuration mode. Use this command to configure a policy that provides the ExtremeLocation server hostname, and the ExtremeLocation Tenant‘s API key needed to authenticate and authorize with the server. Apply this Location policy on the ExtremeWireless WiNG devices (site controller, virtual controllers, and standalone APs). When applied, these devices push/export site hierarchy to the ExtremeLocation server. The site hierarchy includes site details along with details of APs deployed within the site.
Once created and configured, apply this Location policy on the ExtremeWireless WiNG controller‘s self, to enable Tenant site hierarchy reporting by the controller to the ExtremeLocation server.
Syntax
location-policy <LOCATION-POLICY-NAME>
Parameters
location-policy <LOCATION-POLICY-NAME>Specify the Location Policy name. If a policy with the specified name does not exist, it is created.
nx9500-6C8809(config)#eloc-policy testLocPolicy
nx9500-6C8809(config-eloc-policy-testLocPolicy)#?
Eloc Policy Mode commands:
  enable        Enable this eloc policy
  location-key  API key used for location service
  no            Negate a command or set its defaults
  server-host   ExtremeLocation server configuration
  clrscr        Clears the display screen
  commit        Commit all changes made in this session
  end           End current mode and change to EXEC mode
  exit          End current mode and down to previous mode
  help          Description of the interactive help system
  revert        Revert changes
  service       Service Commands
  show          Show running system information
  write         Write running configuration to memory or terminal
Related Commands
noRemoves an existing Location policy from the system
