ldap-agent
Displays an LDAP agent‘s join status (join status to a LDAP server domain). Use this command When LDAP is specified the external resource (as opposed to local RADIUS resources) to validate PEAP-MS-CHAP v2 authentication requests, user credentials, and password information needs to be made available locally to successfully connect to the external LDAP server. Up to two LDAP Agents (primary and secondary external resources) can be defined as external resources for PEAP-MS-CHAP v2 authentication requests.
This command is not available in USER EXECUTABLE ,mode
Syntax
show ldap-agent join-status {on <DEVICE-NAME>}
Parameters
ldap-agentDisplays LDAP agent related configuration
join-statusDisplays if the LDAP agent has successfully joined a LDAP server‘s domain
on <DEVICE-NAME>Optional. Displays if the LDAP agent has successfully joined a specified LDAP server‘s domain.
  • <DEVICE-NAME> – Specify the name of the device running the LDAP server (access point, wireless controller, or service platform).
nx9500-6C8809#show ldap-agent join-status
Primary LDAP Server's agent join-status : Joined domain TEST.
Secondary LDAP Server's agent join-status : Not Configured
nx9500-6C8809#
